Press suggestions??
RB3offroad
RB3offroad
1,711
4,807
Tempe, AZ
BWAF
BWAF
I get paid to pass gas
8,863
42,472
Carthage MO
Need to press some ball joints and tired of the hassle. Any suggestions on a press? Good, bad... looking at the HF because I can get it quick.
12 ton H-Frame Industrial Heavy Duty Floor Shop Press
The one you are looking would be great for disassembly but I always preferred one like this for putting stuff together you can feel more
Screenshot 20200428 055657 Samsung Internet
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
I have the Harbor Freight 20 ton. I never used it with the stock jack. I bought a HF 20 ton air over hydraulic jack. I have it set up for both hand and foot operation. I added 80k press plates to replace the cast plates that come with it. I also added a Swag off-road finger brake kit. I added a Swag release knob as well
XMHF Pneumatic Foot Pedal Valve 2 Way 2 Position Air Pedal Valve Foot Control Switch 1Pcs Amazon.com: XMHF Pneumatic Foot Pedal Valve 2 Way 2 Position Air Pedal Valve Foot Control Switch 1Pcs: Home Improvement
Overall I'm happy with the set up. It's easy to use, easy to control both up and down and it'd a lot more robust than the 12 ton press that it replaced. I added washers to all the hardware and lock tire to all the nuts. I've had it since November but used it quite a bit since I like to use it. This photo is before the foot pedal which really is nice to use. If you need to slow down the pace you can manually jack the HF air Jack just like the original 20 ton jack.
IMG 20191202 203121
ehart814
ehart814
1,653
3,631
NWPA
My cousin has the harbor freight one. I go to his place to use it often. Works great. Recently pressed out/in a wheel bearing for my beater car. I've used it for ball joints on quads/sideby sides too. I can't think of any reason to buy anything fancier.
Gator
Gator
The Most Unknown Member
2,487
10,456
Louisiana
This is the best answer.
If you share a case of beer with a buddy you become cousins. Then, you can use his press and not have one taking up space in your shop.
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
I ended up with a Harbour Freight press like the one in the pic. Got it from an estate auction. It does balljoints in a-arms just fine if you get inventive using little pieces of pipe or deep well sockets to press them in or out. Ive cut pieces of angle iron I keep with it for spanning the gap of the beams down below to set stuff on. Its not something that gets used very often but Im glad I got it. I think it will do you just fine.
115,707
I have always used one of these. Of corse mine is Mac Tools and have had it over 20 yrs but this one is basically the same. Reason being some trucks we had, were easier to do it on the truck but off the truck and in a vise it works as well also. I use a impact air gun with it. The one your looking at are real nice if you have the space to store it. I used the one at the shop when I had issues and needed some more guts but that wasn’t very often
43,057
If all you need is balljoints, these work well without removing a arms.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I'd go this ^^^^^ route @JTW I think the most important factor though is having good plates to be able to adapt to your needs. That is what really makes using a press easy or difficult.
Mopower58
Mopower58
Unburdened by what has been!
79,806
708,790
Crystal Springs,Ms.
I have had the HF press for 20 years and never a problem other than I dropped one of those plates and it broke in half. After the Covid outbreak no more China stuff for me even if it is cheaper.
So is the 20 ton that much sturdier than the 12 ton? I just figured they’re the same frame with different bottle jacks. I’ve looked at arbor presses too, but I’m not sure how much pressure I need. And yes, @ToddACimer I’ve already been looking at the pneumatic bottle jacks.
