Press suggestions??
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
So is the 20 ton that much sturdier than the 12 ton? I just figured they’re the same frame with different bottle jacks. I’ve looked at arbor presses too, but I’m not sure how much pressure I need. And yes, @ToddACimer I’ve already been looking at the pneumatic bottle jacks.
The frame on the 20 is a lot beefier and it's wider as well. Overall it's a lot better frame. I used to have a 12 ton orange press. The 20 ton gray one has a lot larger rod under the jack too
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
Pneumatic is nice but if You want a good feel on what is going on to finesse something manuel is better,,,,
Mopower58
Mopower58
Unburdened by what has been!
81,327
718,211
Crystal Springs,Ms.
Mine was a 10 ton. Never needed more than that.
Reactions: Biteme and JTW
Vikes79
Vikes79
SKOL!
11,786
114,230
South Dakota
  2. Talon X4 LV
I have the Harbor Freight 20 ton. I never used it with the stock jack. I bought a HF 20 ton air over hydraulic jack. I have it set up for both hand and foot operation. I added 80k press plates to replace the cast plates that come with it. I also added a Swag off-road finger brake kit. I added a Swag release knob as well
XMHF Pneumatic Foot Pedal Valve 2 Way 2 Position Air Pedal Valve Foot Control Switch 1Pcs Amazon.com: XMHF Pneumatic Foot Pedal Valve 2 Way 2 Position Air Pedal Valve Foot Control Switch 1Pcs: Home Improvement
Overall I'm happy with the set up. It's easy to use, easy to control both up and down and it'd a lot more robust than the 12 ton press that it replaced. I added washers to all the hardware and lock tire to all the nuts. I've had it since November but used it quite a bit since I like to use it. This photo is before the foot pedal which really is nice to use. If you need to slow down the pace you can manually jack the HF air Jack just like the original 20 ton jack.
very nice!
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
Go with the 20Ton at HF
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Seems to go around on here 😉 "just by a F****** buy a Badazz press and be done!!
No.. this is the route I’m leaning
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Yeah.. I’ve done it before. I’m just not a fan. I’m half way to a press with the balljoints and bearings I’ve f***ed up doing that.
Im sure you know i was joking....i use a 25 ton hyd. Press for ball jints and wheel bearings
Reactions: Biteme and Mudwing
105,595
