Press suggestions??
105,595
That reminds me of another video I have...
1588135205063
115,818
Yes.. but I’m not joking about using a hammer and blocks to beat a bearing in. And I haven’t had great luck with the little C clamp style @Remington mentioned. Maybe it’s just the Indian and not the bow.
They can certainly be a PITA. You have to be patient with that tool especially when pressing a new ball joint in. If your using an impact gun, back off the air pressure a bit so you don’t over press it too fast and cause the anvil to run off the top of the ball joint, binding and destroying it . Last thing Is you have to have a good frame of mind in order to press that correctly. If your stressed, worked up or pissed off you’ll Fvck it up easily. I’ve done that a few times. If it’s not working, just walk away and come back later.
Vikes79
Vikes79
SKOL!
11,786
114,230
South Dakota
  2. Talon X4 LV
So I drive an hour to HF and it’s 2 minutes past 5:00 (I’m an hour behind it’s 4:02 my time. The dude tells me they’re closing and I go off, walk back to the car and b**** to my wife. I decide to say f*** it and go in anyway. He sees me and starts to say something. Soooo, I make a scene and fuss. He asks the manager and they say let him in. I run back and get one of the things I need and I’m scurrying around the store trying to find the presses. I finally see it and grab one of the little things. The same guy comes up and asks what he can get for me... I tell him what I’m after and he says, well, if you are mad before you’re going to be real mad at me now. We don’t have any. MOTHER f***ER!!! We kiss and make up and look in the back. Sure enough, they don’t have either the 12 or 20.
43,292
Did you try having sex with him?
Rapman
Rapman
5
10
Kingman, AZ
  1. Talon X4
Need to press some ball joints and tired of the hassle. Any suggestions on a press? Good, bad... looking at the HF because I can get it quick.
12 ton H-Frame Industrial Heavy Duty Floor Shop Press
If you only need to do a couple, and you are not doing this on a regular or business basis, simply use your vise. I have done quite a few with mine and
did it very easily and had no need for a press.
Reactions: Biteme and JTW
