P1000 Project "Snowball"
Superthrill
667
1,558
North Carolina
That plate is 3 inches wide and welded inside and underneath backside of that square tube the full 3 inches. Then welded to the diagonal. It aint going anywhere.
Reactions: JenElio and TripleB
Superthrill
667
1,558
North Carolina
There is another option that i have drawn out that can be bolted in. Got somebody that may make them, but it requires more tubing etc. It attaches to the rear shock tower upright tube AND the front tube behind the radiator. Runs behind the shock. Had to get real creative with that design but it was one of those AHAH! Moments when i figured it out.
JenElio
JenElio
82,903
718,452
Loxahatchee, florida
So if you do end up making these let me just say I'll buy one. My wife has been asking me to come up with somtn like this but I just haven't got around to it. Nice work!
Superthrill
667
1,558
North Carolina
Got my last fairlead for the top winch installed last night. Wished i had made it tuck in a little higher, but did not want to cut the top. I did want it out far enough to go down to the rear hitch with a snatch block if i need a low pull.
20200504 154537
Superthrill
667
1,558
North Carolina
Now basically anything i can get up with a winch, i can now get down on my own.
I swore this was going to be the last thing i added to the P1K...
But racing type bucket seats ,retractable harness, a HMF muffler and a full custom cage.
Then I will be done...
Ahaha! One other thing. A burrito cooker for the engine compartment!
Superthrill
667
1,558
North Carolina
Going in today coming out Monday. Doing sandcave, chalk cave and primroy arch.
Reactions: TripleB
Superthrill
667
1,558
North Carolina
Weekend riding solo in Tackett. Chalk Cave, Primroy Cave, Primroy Arch, Ridge Trail and Overlook.
20200509 154705
Chalk Cave. Huge! Pretty wet as well.
20200510 130647
Primroy Arch.
20200510 141556
Reactions: Mudwing and TripleB
Superthrill
667
1,558
North Carolina
Tie rod on the Primroy Creek Trail
Had to come home yesterday. The Pioneer started shutting off. Would crank right back up. Noticed on the road ride back to the truck, it did not feel like it was running right.
Got to check the ground and the injector harness...
Reactions: TripleB
Superthrill
667
1,558
North Carolina
Pulled the pins out, soldered wire back in, reninstalled pins. Added the liquid tape for some added vibration protection.
Just got to reassemble everything and ready to go!
IA-AJB
IA-AJB
12
23
Iowa
P1000-5. Was supposed to be just a run around toy , but.....
Will add to this first post each time I make a mod.
Mods so far:
Viper Max 4500 winch
Moose snow plow
Tru Isolator
35 amp hour second battery
RAM mount for 8" tablet
Rock lights
Glove box light
9 " LED light on A pillar
4" flood LED on B pillar
Rerouted vent lines
PBR shock spacer lift
Did you notice much difference in the ride after adding the shock spacers?
Reactions: JenElio
JenElio
JenElio
82,903
718,452
He hasn't been on the site in a while bud. I've been running shock spacers for a while now and it's not a drastic change on ride comfort. Stock shocks kinda suck to begin with sooooo....... What ever little comfort is lost by adding that bit of preload to the shock is a good trade for the 1.5"+ ride height you gain. One of the cheapest mods you can try, that and eliminating the rear sway bar 👍
Good luck
Reactions: Mudwing and IA-AJB
EMAW
EMAW
Mama Tried!
3,693
46,525
Kansas
My OEM rear springs were sagging bad after our trip to NM. I installed new springs from S3 Power Sports. I gained 1.5” ground clearance with no spacers. Going to replace the front springs also in the near future.
Similar threads
