P1000 Project "Snowball"
Superthrill
667
1,557
North Carolina
Trail report. First trip out on 30's amd SATV forward A arms.
LOVE the clearance and ride on 30's. Had some concern with the mudholes on the Grippers, but made it though all of them no problem. Several were about 6" inches of water in the floor board.
Rocks, that is why i go these! Freakin awesome in the rocks and ledges. Made a few ledges i was never able to on Bighorns.
I did kill a sidewall and a balljoint in one nasty spot. Hope this was just a freak. I will tear it down if it starts leaking and add a boot inside.
Snap rings for lower joints are next.
20190804 100248 600x800
Reactions: CumminsPusher
Superthrill
667
1,557
North Carolina
There was a rock ledge that had just busted and had some sharp rocks. Also was a half burried steel culvert that i thought I missed. Dont know which got it.
20190804 100259 600x800
These things stuck to rocks like glue.
Reactions: TripleB
Superthrill
667
1,557
North Carolina
Cool thing about the whips?
Turn them on when backing the trailer and they make great backup lights while trailering.
Superthrill
667
1,557
North Carolina
Earlier this summer i had issues with the Viper Max that almost left us in a bad jam in Windrock. I ran across a Superwinch Terra 45 for a good deal. The Viper had gotten water in it. Got it cleaned up and working . It will go on the back soon.
20190825 154326 600x800
61,478
Be careful those whips don't smash back into your roof if you catch a limb. I killed some like that on my ATV and got shorter ones for P1K because of it. On the ATV they bent way back then sprung forward into my speaker and would only flicker for a second then go out.
Reactions: Mudwing
Superthrill
667
1,557
North Carolina
They are mounted at a backwards angle to help some. They hit a few times. Got to sort that out. Tennis ball maybe or something..
208,731
I went to Tractor Supply and got some clear tubing, split it and zip tied it on about 8 inches long
Reactions: Superthrill
ToddACimer
ToddACimer
Pioneer 1005-2
3,745
15,855
Oshkosh, Wi
It's nice to see the Terra45 next to a other brand. The body is bigger which surprises me because it packages very well. Hearing that it's quieter and faster is cool. The biggest plus side to me is the Terra45 is one of the lowest current draw winches on the market at 4500lbs, it's also been shown to pull over 4500 with a strong electrical system. I think you'll really like the upgrade
Superthrill
667
1,557
North Carolina
Damn... another sidewall. Probably need to stick to manufacturers recommended psi of 22 lbs.
20191117 163415 600x800
Superthrill
667
1,557
North Carolina
They have changed tire designs o. The new ones....no longer true to size.
20191117 163524 800x600
Superthrill
667
1,557
North Carolina
Santa came early. SATV rear arms and a JBL Prv-275 head unit for my stereo setup.
Got both installed today.
SATV arms first. This was a 2 beer per side install. Only issue was bottom frame mounts had to be spread a little to get the joints/arms in the bottom. Top slid right in.
Comparison of stock and SATV.
20191224 085110 800x600
Similar threads
