Jankyeye
Looking for rear radius rod inputs. So far I have the list below:
AJK Offroad, $889 for a powder coated upper and lower set, $542 for lowers only.
LWFAB, $465 for full/$275 lower only (color matched)
CATech, $594 for full set/$404 lower only (color matched)
SATV, $499 full set (black only)
RACECO, $695 full set (black only)
Hess Motor Sports, $650 full set/$450 lower only (black only)
WC FAB, $590 lower only (color matched)
Dragonfire Racing, $329 full set (black only)
Have I missed any? Does aluminum vs Steel matter? Appreciate the help.
Honda Talon High Clearance Radius Rods - AJK OffRoad
HUGE!!! Our radius rods are HUGE compared to some others. Our Billet aluminum radius rods work with the Honda Talon X AND R model.
ajkoffroad.com
Honda Talon Radius Rods (R Edition)
Honda Talon Radius Rods ( R EDITION ONLY) These Radius Rods are made out of 6061 Aluminum. The raw option is a billet finish. Made in the USA
landwfab.com
Honda Talon High Clearance Radius Rods | CA Tech USA
CA Tech USA Talon High Clearance Radius Rods / Arms are the largest and thickest rods on the market providing strength, dependability, and affordability. Thickness of 1.25 inches and height of 1.5 inches. Built with FK Brand Spherical bearings. Kit contains four high clearance rods and two...
catechusa.com
Honda Talon 1000R High-Clearance Boxed Radius Arms
Make your rear suspension bulletproof with a pair of Honda Talon 1000R Radius Arms from SuperATV! They feature a high-clearance bend and aggressive boxed design.
www.superatv.com
TALON R/X RADIUS ROD KITS SET OF 4 — Raceco-usa
- 7075-T6 AIRCRAFT ALUMINUM - 75% STRONGER LATERAL LOAD THAN 6061-T6 - HARD ANODIZED - CNC MACHINED - CHROMOLY TEFLON LINED FK-JMX SERIES ROD ENDS - 17-4 HEAT TREATED MISALIGHNMENT SPACERS
www.raceco-usa.com
Honda Talon R Heavy Duty High Clearance Radius Rod Kit
We designed our Honda Talon radius rods for strength and clearance. We don’t want a radius rod failure to end a race or a riding trip. Replace the weak OEM rods with our Heavy Duty Rods before yours fail. We use the 7075 Aluminum for the ultimate strength, and our uppers are adjustable so that...
www.hess-motorsports.com
2019-2023 Honda Talon R Billet Lower High Clearance Radius Rod Kit
- Largest, strongest, and highest clearance on the market - Increases ground clearance in the rear by 3 inches - Designed, tested, and manufactured in the USA - Available in three finish types: Cus
www.wcfab.com
Honda Talon High-Clearance Radius Rods | Dragonfire Racing
High-Clearance Radius Rods for your Honda Talon from DragonFire Racing designed to improve or replace the factory rods on the Honda Talon. Made with high-quality chromoly for unmatched strength Increased ground clearance.
radutvparts.com
