Because I sometimes I am a Hypochond
ariac and I have seen
@ohanacreek and
@Windrock1000 post on the super ATV arm wearing the hole on the frame portion - I decided I had to check mine out. The top bushing bolt hole on the frame looked to spec.
But when I pulled the bottom A arms and looked at the sleeves and bushings I noticed what I thought was a raised area
. Having nothing to compare to and know that I would need them eventually I ordered a set of the replacement bushings from Super ATV.
Here is how the bushing set comes for the front
Here are the new and old bushings and sleeves for comparison
I then measured everything only seeing slight variations - not going to go through all the measurements but will post some of the Pics
the major difference is in the sleeves - the old one has wore down a little (very little) to where it looks like the section not covered by the Bushings is slightly raised like a a couple thousandths of an inch - as if the bushing "sanded down the sleeve"
I am now keeping them full of grease on an pretty regular basis - since changing out the grease ports to angle ones that I can actually get a grease gun on to.
for now I don't think i will change them out as i am not getting any movement when i shake the A arms back and forth. - just keep them greased up and watch.
