Ragnar406 submitted a new Garage Item:
Ragnar's Ride And Adventures
Read more about this showcase item here...
Here is the only video of part of the ride that I shot
Yes, I started taking this video about halfway up this trail - which is the first one we all took after you left. I was 2nd behind Cody and we were hauling - I only slowed down a couple of time to wait on the next in line. I wish I had filmed the rocky first part of this section - it was my first time really going for long with the Fox shocks on Soft which I likedThis is after I left isn’t it?
I went through 2 amazon cheap subs that I had installed under the drivers seat - seems that they would handle the ride vibration fine but water got both. I said that if I ever replaced again I would replace with a wet sounds sub. I did not want to have the Sub in the floorboard as my son will still ride in the middle seat from time to time and no doubt something would happen. So I went with the 8" Wet sounds under the drivers seat. Yes it fits but it takes up all the room. Prior to ordering I even went an built a cardboard model to test fit.
It is still working after Takeover (and we went through a lot of water and mud) only thing I need to do is change some settings - I made all adjustments when the Honda was in the garage (it was cold outside) and I need to go back and adjust the Gain and bass boost when it is outside - both have lots of adjustment left. below are pics when first test fit
View attachment 73552 View attachment 73553
You tried to roof mount the Wet sounds AS8 sub? Making sure I am reading that right. Mine is still doing good, I have been through quite a few mud hole and streams that have reached the sub's current level. I simply lift the seat and spray off - seems to be holding up well. I still have not gone back and adjusted the 3 dials in the back of the sub since my first attempt. it is plenty loud and really adds to / completes the sound from the WS soundbar.I h
I have the same sub first tried roof mount now have it in floor. Not as loud as I wanted with Wetsounds bar in addition. Looking at other options how is yours doing
IYou tried to roof mount the Wet sounds AS8 sub? Making sure I am reading that right. Mine is still doing good, I have been through quite a few mud hole and streams that have reached the sub's current level. I simply lift the seat and spray off - seems to be holding up well. I still have not gone back and adjusted the 3 dials in the back of the sub since my first attempt. it is plenty loud and really adds to / completes the sound from the WS soundbar.
The sub feeds through my Stealh sound bar. The stealth syncs with it and runs it.How do you have the sub audio Fed?
I ask because if you are splitting from a single output on a radio or phone etc... to then send to the sound bar and the sub. You are going to get less than half of the output that each can provide. I had to find a radio that had multiple pre-outs that would feed a full signal to the inputs to get any real volume. I even had WetSounds Bluetooth Rocker and it wouldn't feed enough power....
I
Ragnar yes I drilled holes through roof and bolted sub to roof right at windshield facing me in middle. I was worried about getting water and mud in it. Then I just put super ATV 6 inch lift on and I didn't like the big feeder wire coming down so changed it back to floor. I wanted it under seat but actually had put marine battery there to power all this. Have another Kicker flat 8 inch sub in roof in back and 2 Kicker 6 inch wake speakers from back roll bar
Got it, I know the sub has a little weight to it so that why I asked. Wet Sounds also says to experiement with placement as the front of the sub needs to be facing a wall(?) to load into. Granted what is loud to both you and me is different but mine definitely puts out some bass. I don’t even have my gain or bass boost turned up all the way. I am assuming that you adjusted the three dials on the back. Did you see much change doing that. Give me a song to play and I’ll see what I can record as an example of mine.
So you can order different plastics and i don’t the Part numbers are listed on this site some where. I want to say for everything (this includes fenders) different color plastics were around $200ish (probably a little more). But you can order them and they are cheaper at a place like bike bandit or Rocky Mountain Atv.Another question completely off topic. Mine is all white and I like the black models. How hard or better expensive is it do you know if I wanted to mix some black panels like doors to change the look to more custom can you order different color plastics?
I haven't adjusted any controls on back so I do need look at that. My kicker roof sub blew so getting ready try regroup. Crutch field has a bass tube deal they suggested. Mine is plenty loud sitting off but going down road or riding is when is when all drowns out. I was worried about roof weight too but it was fine on stock roof no sagging. My buddy has Kicker 12 sub under Polaris Ranger seat and it is loud as heck any time. I'll try those controls thanks I really mounted and forgot may make a difference.
That looks more like baby s***... I thinking someone is f***ing with you!So I opened up the rear boot kit from Honda
View attachment 88535 A pouch and a bottle of grease
A new c clip
Boots and bands
I then opened up the front CV boot kit and what the heck the grease is mustard color
Maybe... those fing cv boot bands sure are. I had ordered some of the easier ones but only received the short size so I have take pause from trying to get the factory one installed - that SOB sucksThat looks more like baby s***... I thinking someone is f***ing with you!
