I've mentioned before, it looks like an ape with a 1000 psi impact driver put in the fasteners on my '21 P1K5 SE. It's as if he removed the impact driver while it was still turning, you can see the damaged 5mm hex drive hole and know it's screwed up beforehand. Usually tapping in a hex drive bit with a hammer, a new quality bit such as the Wiha I'm using, will get most loose. Not all though.
Getting ready to install a Shifter Hole Cover , so figured I'd check the bolts, both looked rounded. The "tap the bit in" drill worked on one, the other stripped. It's in a recess in the plastic so I can't get a Dremel in there to cut a slot.
I could disconnect batteries (to help prevent damage to electronics), connect my MIG welder ground to the frame (as near the offending bolt as possibible). Hold a suitable nut in position and weld into the center of the nut to weld the nut and bolt together, then use the nut to remove the stripped head bolt. I'll cover everything with a damp cloth to prevent collateral damage. The panel plastic melting adjacent to the nut is of little consequence as I can put a washer in the recess later. I'll have a water spray bottle to cool things off after welding.
I have a TIG welder available, and would be inclined to use that if it were home, as it welds with more finesse, I'd have to fetch it from my hangar if that would work better?
Any thoughts, experience doing this, comments, better ideas (please!) are most welcome . . .
