P1000 Replacing clutch pack on the Beast
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Under $400=2 gallons Honda oil, 2 o rings, oil filter, dct filter, 1 clutch pack,...But the real cost is not being able to ride and for me that is the highest cost.
When I started it up today and pulled it out of the garage I reved the engine and it grabbed and I almost just took off! I spun a cookie and pulled it back into the garage and it was enough of a "fix" for me for another day! Weather is warming up and I'm going to take advantage! That is why I drove almost 200 miles today for filters when I had some on their way in the mail!
Eltobgi
Eltobgi
4,599
15,187
North Dakota
IMG 6289
Now I think I should have drove it at least another 6 miles:rolleyes:
IMG 6290
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Who are they going too?
@snuffnwhisky asked me if I would let Barnett Clutches use them for R & D! As any good forum member would I said yes! The goal=a better Aftermarket Clutch Pack;) I may get it back after and then @1BadDart would be the next in line
popeye
popeye
3,275
14,644
kapowsin, Wa
Thats awesome. Good going
X4Dice
X4Dice
87
130
USA
My dealer sold me Pro Honda HP4 0W-30 for winter months, it's a synthetic blend. I'm going to change oil next week. 6 qts of 10w-30 at -20 hurts.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Without seeing it in writing within the manual I couldn't do it! I most likely wouldn't be starting it when it is -20 below. If I had to I have heaters that I could put in the engine compartment that would help warm it up a little.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Had it warming up over night...
IMG 6291 IMG 6292
The engine was warm to work on in my garage that was probably 30 above temp
Eltobgi
Eltobgi
4,599
15,187
North Dakota
At this point I was supposed to take a break and grab a cold one but on my lunch break and in a hurry at this point
IMG 6341
IMG 6342
Old O-rings removed and new installed ensuring no debris and oiled. With clutch pack still in the same position carefully lined up new soaked clutch pack with splines on shaft. With the palms of both hands applied equal downforce while holding underside of gear with both hands and slid new pack on! Again without the use of hammer and socketo_O
IMG 6343
This pic shows different gaps on each side of the visible gear. The lower & larger gap faces outside;)
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Lined up splines in both packs with gears installed and reinserted!
IMG 6347
Still needs to go in about 2 inches. So grab a big hammer and hit it as hard as you can to force it in:confused:
Just kidding! Do not use a hammer!
