Good day folks...
I found this thread, when I was researching my same/similar issue.
Drove the P1000-3 on my property as I always do... 15 minutes later (after shutting it off, restarting and driving along), it falls on it's face. No power, barely idling, and when put in gear it won't go. Either the clutches won't engage, or when they do... it dies.
After reading about the 1000 issues. I did the following;
- checked the fuel injector leads and associated wiring/crimps (good and solid)
- pulled the coil wires, to see if I could find if it was a bad coil (seemed to be the front plug's coil or plug)
- pulled the spark arrestor, and ran it without (same issues with it out of the muffler)
- pulled the plugs, and checked spark on each plug/coil. (nice spark)
- pulled the battery positive, and let it sit. Reconnected, and still ran like crap.
I'm at a bit of a loss, and I don't want to start throwing money at it just yet.
It'll run, but pop and sputter. Seems to only be running on one cylinder. I thought to also try and swap coils and actually did at one point, but only the wiring. Uhm... probably not a good idea, as it seemed each coil is timed with the cam?! It didn't like that. SO, maybe I'll still try and swap coils, swap plugs, and see if the problem follows the coils or the plugs. But, after I did the above, and they both have a good solid strong spark... I figured they're "good". What do ya'all think????
HELP!!!![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
HELP!!!
