P1000 Simple reverse light?
K
Kolton
117
82
Vance, al
I know there's threads out there with some writing ideas for reverse lights, but has anybody tried adding a limit switch in the dash so that the gear shifter will rest against it in reverse? Anybody think of a reason it won't work?
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Just tap into the backup alarm harness. Ezee peeze. Type reverse light into the search bar..there is a ton of differnt ideas.
Heres mine...
IMG 20170227 174842804
63,529
Heres mine...
Yes, this "limit switch" is already built in. Just need to tap it.
See - P1000 - Key On Power, Illumination, and backup source! - Honda Pioneer 1000
Hooking a light up to these two wires will give you want you need. It will easily run a small/med reverse light (15a Max) or if more power is needed, just utilize the ground trigger wire as a (in reverse) negative trigger point for controlling a relay.
Amre2me2
Amre2me2
381
1,423
Colorado
I taped into the alarm wire harness for my reverse lights but originally only used the positive wire. Found out the lights stayed on all the time. I figured out that it was the ground wire that triggered the lights when put in reverse. Then I went back and read the posts on here telling me everything I needed to know.
K
Kolton
117
82
Vance, al
If you don't want to modify your machines harness the Honda accessory harness is 08Z02-HL3-A00 and it plugs right into the reverse alarm harness.
Is that a kind of reverse light kit?
Mudwing
Mudwing
36,959
306,563
The Mud holes
It's just the harness. Honda uses a back up beeper not a light. You can use the harness to run a light instead of splicing into main harness.
E
elkguide
3,377
7,963
Vermont
So what you're saying is
that when all else fails.......... read the instructions?????????????
ToddACimer
ToddACimer
Pioneer 1005-2
3,558
14,599
Oshkosh, Wi
I wish I'd gone this route. Cause getting to that plug and splicing into the wires is no easy task. Guess it proved I'm more cheap than lazy huh?
I'm all for adding mods but I'd rather not permanently change anything. I've overcome a slight fear of drilling holes but I've avoided hacking up wiring
ToddACimer
ToddACimer
Pioneer 1005-2
3,558
14,599
Oshkosh, Wi
Is your rear winch removable? I had my stinger in last ride and hit it coming off a big rock ledge, think I bent something/
That's called a tiger tail, it's a spring loaded retractable tow strap. I've hit it hard enough to rotate it in the slotted holes but I don't take it out for trail riding. It's super convenient if somebody gets stuck. They grab it and hook up, when they are out it retracts and we keep going
