P500 Skid plate
NitroxDiver
NitroxDiver
488
918
Concord NC
Anyone using the Honda aluminum skid plate in their P5? I’m also looking at the SSS plate too but not sure the mud building up on the outer areas of the plate under the floorboards.
Reactions: KyGal83 and J80
103,419
I had the sss full armor. It rocked, slid and like underwear, protected my bottom from trail shards...🤣
The Green Goat
The Green Goat
1,733
12,272
The bobsledding down the rutted hills at RRB was a pleasant and fun surprise with the SSS skids. Fall into the 'chute' with all 4 tires off the ground, and away you go!
NitroxDiver
NitroxDiver
488
918
Concord NC
For everyone running the SSS plates are you using the original style or the new one with the rock slider? Trying to decide if it’s worth $150 for that 2” tall outer edge.
Reactions: Mudder
The Green Goat
The Green Goat
1,733
12,272
Rock sliders here. Only because I didn't have nerfs yet. Seemed like a good idea for RRB.
Reactions: lee and Mudder
P
pappyo
593
2,377
Buy Once get the one that will work Best for your style riding.
2009-rzr / 2014 P700 / 2017 P500 - UHM ( SSS ) - on ALL - Will never go back to Aluminum.
If you go Aluminum -
Eventually you will realize why so many use UHM.
Takes a Beating :
NO memory-( doesn't bend or dent )
QUIETER / slides over rough - uneven surfaces / protects plastic & steel tubing under the doors
As for the shelf :
PICKUP Truck Tailgate Liner cut to fit & secured with self tapping screws
Keeps 95% + mud snow & ice Out) Depending on cut & fit skills ( included couple pictures l
left clean out holes - ft. & rear - near frame (for water hose )
And works as floor protection ( stick punctures through floor some have had happen )
20200725 123146 20200725 123200
11,301
83,888
I have aluminum Ricochet rock sliders and full skid plates. Due to the span between the center frame members the plate bowed upward and caused a rattle against an engine mount. I had to flatten it by driving a tractor over it. If doing it over, I would go with UHMW
.C5CCE70E 8A83 41C7 B2FD D6DBBE2C5C2264D73F6A CAC7 40EB 8394 DD8854FEF27D
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
Sorry but a newbie here, what is SSS? And does anyone have a link? I'm in serious need of a skid plate. Loggers left a mess at my hunting camp and I'm tired of pulling sticks out from underneath my ride
Reactions: pappyo
P
pappyo
593
2,377
DIRTBILY
Welcome from Central N.Y
RED was 1st Color All other Colors followed hopping to catch some of the Glory Honda hopes they sell
SSS of Road ( sells UHM products )
4 warned - Pricey - well worth the investment
DIRTBILY
DIRTBILY
279
3,033
Grantville Ga
DIRTBILY
Thanks
34,173
No on the aluminum, it can dig into rocks, and it’s terribly noisy when gravel gets on top of it. UHMW is the ticket.
NitroxDiver
NitroxDiver
488
918
Concord NC
Reactions: Bigtee
11,301
83,888
With branches on the ground, consider a plate inside the wheel well to prevent intrusion in the cab.
