socket question
bjniceguy
322
431
Iowa
has anyone taken the blank spot next to light rocker apart? Is it a bolt in plug /cover? I need 1 more rocker and that looks like good spot if can figure out how to use it??
Reactions: sharp and BWAF
HondaTech
Id say it a blank that would need cut out, thought the factory switches are a little larger than most of the rockers ive run across.
Reactions: BWAF
Bigblue1
77
92
NC
It snaps out but is easier from the back. I have some module switch cut in type holders from Amazon that I could make work but I have ordered a 3 switch plate for the dash above from the Pioneer switch guy on the forum.
Screenshot 20190617 222101
Reactions: CumminsPusher
bjniceguy
322
431
Iowa
thanks, I have to pull the dash top to do rest of wiring so will get it from back. I have a socket to hold rocker that looks similar to what you posted that looks close but wont know till get plug out.
Bigblue1
77
92
NC
It easier to also remove the top part of the inner fender liner also. I pulled my dash top tonight also for the second time to install the windshield wiper.
viceversa
viceversa
20
Flagstaff, AZ
I wonder if we could buy another Honda switch and rewire it for another purpose in this location?
DAJO
182
125
Indiana, Arizona
The Honda switches are huge compared to others. I installed horn switch next to Honda removal plate.
spentcoins
spentcoins
52
70
Alabama
I talked with otrattw, who makes and sells most rocker switches. He is currently looking for a source for the larger Honda switches. I want one for my winch.
Reactions: Razorback
bjniceguy
322
431
Iowa
please post if you come up with larger rocker switch for Winch - I would be interested too
67,170
So I have these. It's a switch holder like above but a single.
If someone has or is willing to punch their hole out I'll send you one to test.
Measurements are...
Roughly needs a 1" x 2" hole.
43d0ad4721022435152f32906f86df4073a32c85f319acbbdc67a36a47b6f7b7
DAJO
182
125
Indiana, Arizona
So what you have is like a bushing for the large Honda hole. I would be glad to test for you.
67,170
I think so.
Can you check measurements. I dont have a talon available?
DAJO
182
125
Indiana, Arizona
The plug (dummy hole cover) measures 1 3/16" X 2 3/8". This is the area that sits flush in the panel.
67,170
Close. Think it's too long.
Sent you a message.
DAJO
182
125
Indiana, Arizona
Did you notice when you buy the horn kit it does not even come with a switch that would fit in the hole left of the steering wheel. The switch that comes with the kit requires a new hole to be cut in dash.
67,170
Yep. That hole was purposefully saved for Live Valve. Yes even tho it will not be available for eirler models.
Reactions: BWAF
spentcoins
spentcoins
52
70
Alabama
I'm gonna order a sport/auto-mt switch and label it for a winch. It is momentary 2 position and should work fine for winch control.
Reactions: viceversa and BWAF
Bigblue1
77
92
NC
Measurements are...
View attachment 136540View attachment 136541
The one I posted a picture of will actually fit better with the side that doesn't have the flange on it up next to the headlight switch. The flange gets in the way. It fits but you will have to rig it to get it to stay in but it is doable. I test fit it a few months ago.
bjniceguy
322
431
Iowa
I have to remove the light / dimmer switch. Normal Rockers have a tab that you push down with screw driver. Does this one have same?when I shine light, I don't see tab??
spentcoins
spentcoins
52
70
Alabama
Got the switch installed and worked out perfect.
You have to cut the connector off the new switch first.
Wiring,
Yellow is sport side at switch and I used it for winch in, connect it to the green control wire on winch contactor.
Blue is at/mt at switch and I used it for winch out, connect it to the black control wire on the winch contactor
Black is +12vdc common at switch and I used the switched white wire on the dead end plug to power this black
The two white wire on the switch are for lights and I chose not to use them. All that is left is stickers.
20190702 150458 20190702 151226
Reactions: nm6r and viceversa
