P1000 Sound system
Wellzy
Wellzy
269
900
SW Wisconsin
I have only been using a Bose Soundlink bt speaker as I have only had the machine a week. We are planning on adding an overhead system in the Spring. I am looking at something like my friend's Swamp Donkey or a Froghead Industries. I want the entire unit enclosed with only the power and ground to run down the frame bar to a power source. I would probably get better sound out of a unit with a pod in all 4 corners overhead, but I don't want to wire all the components together and have exposed wires. Toooooo many choices when looking at what other owners have bought/made.
Worse1
Worse1
145
554
Arizona
I went all out. JL audio system.
162CC4D7 4684 4875 9C64 A4451E8BA23D
04A4813E C213 4989 9B76 659A17ED37B2
F
fsk1290
81
258
Grant, FL
SSV Works overhead is the tuner, two 6 1/2" Infinity's in that. It also drives two 5 1/4" Polks mounted in pods on the underside of the roof. Alpine amp drives Infinity 6 1/2" components in kick pods, tweets are on the dash. Two 10" Rockford Fosgate subs right behind me. 10 speakers and 1000 watts RMS, it hits pretty hard.
Edit: all contained too, you don't see it from outside of the machine.
Good Lord!!! Pics of this massive system please. How many extra batteries do you have on this thing?
182,107
I'll post some pics when I get home tonight, it's changed so many times I don't think I have anything current. I posted a sound clip a while back too that I can dig up. Only one extra battery mounted under the seat.
jpanicaro
38
111
SWFL
I'd like to see it as well, I have (4) 6.5" Skar in a custom fiberglass roof I built with a 10" Skar sub. Its clean sounding but no overwhelming bass.
182,107
Here's the SSV overhead. 50 watts per channel rms, it's driving two 6.5 Infinity's and two 5.25 Polks in roof pods.
Infinitys and Pod
These are 6.5 Infinity component speakers, tweeters on dash and crossovers mounted under the hood. They're driven by an Alpine 200 watt amp mounted in the box with the subs.
Storage Net
These are powered 10" Rockford Fosgate subs in sealed boxes, 300 watts each. Storage box is vented and lined with a cheap Dynamat.
Stereo 2 Vents
Second battery under the seat, mounted a jack under there too.
Battery and jack
Here's a pic of the machine. None of it is visible unless you go looking for it.
Cowl 2
DaddyDubbs
DaddyDubbs
14,911
140,760
View attachment 243706 View attachment 243707
I’ve seen Triggers machine (although not with his latest audio upgrades), but the old audio system was quite impressive.
If you want to know what to upgrade for any Pioneer (especially a P5) just ask him, if he doesn’t have it, you don’t need it. :cool:
Without question, he is the go to master of accessories and add-ons, and I mean that with the utmost compliment to his ability, his work is truly a craft and work of genius.
  • Wow
Reactions: Biteme and trigger
00Buck
5
7
MS
I went cheap with the boss head unit in the dash & added two more speakers in home made pvc speaker pods. It’s loud enough to hear over wide open engine noise clearly. I do plan on adding a sub in the future for better sound though.
E756A67C E462 4516 9A8C 363D4EC0E5D8
Worse1
Worse1
145
554
Arizona
So many questions about this set up?!?! Is there another thread of your jl audio setup? AMAZING! 🤩
No. This is all I posted. You can always DM me if you have questions on the setup.
