Run well when they do startJust to clarify, Bigshoe, are you saying you've seen other Pioneers start/not start intermittently, but run well when they do go, or you've seen others with similar spark pattern?
Unrelated to the issue, but What brand of filter did you buy? I've never seen one with those options?Thanks. The filter comes pre-oiled or dry, and you can buy the oil. I selected the pre-oiled option.
Good to know about the valves. I'll start looking for a valve adjustment guide here on the forum. I'm sure somebody has probably already posted one.
I figured they should fire simultaneously. I just thought they would fire a heck of a lot more than 1 spark per second.your plugs should fire at the same time, thats not a problem, did you ever check compression? How did the old plugs look? A quick shot of ether to see if it will fire will eliminate the spark plugs if it fires, then you could start looking at a fuel problem
Here is a pic of the old plugs. Look decent to me. White-ish tip. A bit brown at the end of the insulator. Don’t know how long they were in there.your plugs should fire at the same time, thats not a problem, did you ever check compression? How did the old plugs look? A quick shot of ether to see if it will fire will eliminate the spark plugs if it fires, then you could start looking at a fuel problem
The spark arrestor screen is missing. It's a tube of wire mesh about the diameter of that metal the gasket is around...Like the pic in the manual.Interesting find on taking 3 minutes to clean out my spark arrestor (you never know). Does not look like the Honda manual I just purchased. See pics. The screen is large and stays inside the tailpipe. The only thing that comes out after removing the (3) 8mm bolts is a short piece of pipe. Nothing came out for me to clean. Sorry, no torque spec listed. Default to 8mm bolt torque
View attachment 250777 View attachment 250778 View attachment 250779
The pre-oiled air filter was purchased from my local Honda Powersports dealer. The packaging was just a clear plastic bag - no labels.Unrelated to the issue, but What brand of filter did you buy? I've never seen one with those options?
Can you post a video of the spark/cranking going on? The engine should have a distinct rhythm when cranking, and the spark should match that. Doesn't really sound like the issue, but I'd like to hear and see it.
My DR650 dual sport motorcycle has a lost spark ignition as do many others - they fire at every TDC. It wouldn't surprise me to learn the SxS do it too. I am curious about the change in frequency though, it obviously gets cut in half.Here...
My 2020 lower plug. Your 2016 should be the same.
It looks like it is fired 2 times per cycle for the 1st few cycles, and then reverts back to the once per cycle event you'd expect.
This may have actually answered a question I've had for a few years, and that's how does Honda know when to fire the injector and spark without a camshaft position sensor (remember that the crank position sensor would pass 2 times per 4 cycle event). My guess: maybe sensing vacuum pulses in the map sensor, and until it gets that sync, it simply fires at both crank signals? I'd bet the injector does the same thing (or maybe not???)...and I'd bet this is why these things always take a few seconds to start? And are grumpy cold weather starters.
Lots of older autos use "waste spark" systems. Same coil fires 2 plugs: the plug at tdc compression and the "opposite" cylinder which is at tdc exhaust, where there is no harm in it at all.My DR650 dual sport motorcycle has a lost spark ignition as do many others - they fire at every TDC. It wouldn't surprise me to learn the SxS do it too. I am curious about the change in frequency though, it obviously gets cut in half.Thanks for the video, learning every day.
Ha ha. Yes. I did remove the air filter and sprayed the either right up the tube. Tried with both no throttle and WOT. No difference. I was really surprised that I didn’t get a bark when I sprayed it right into the cylinder itself and didn’t even get a bark. Yes. I did have the other plug installed, plugging the hole, with the wire disconnected from it.Load the video to youtube and post the link.
A lot of things go into actual compression psi. Altitude and cranking speed have an effect as well. Honestly, my experience with ether is that it will start an engine with too low compression, but thanks to EPA screwing with stuff, maybe that's not true anymore. Maybe try ether again with throttle open? (You did remove the filter, right?)
50 at WFO throttle at NORMAL cranking speed is low, as you observed. Are you way up high in Colorado some where? You did have the other plug in, correct? (Yes it's obvious, but I have to ask)
Are you sure you checked the valves right?
Maybe it doesn't fire the injector all until it gets that sync (again, no harm firing the plug every time). I've had my suspicions, but figured it'd be hard to illustrate without a lab scope. The point where the spark cuts in half is probably the point where the ecm finally determines which tdc it needs to use.
@HondaTech, any input?
Both on the same coil and only 2 wires, so they have to fire together. I believe the second plug was done for emissions. Suzuki did the same thing in the king quad around the same time.The dual plug 700 engine is for emissions reason im gonna guess, not sure if they fire both or one as main and other as waste.
I cant locate it, but i want to say their was an article about thr Map sensor being used in place of a camshaft positions sensor to help determine firing, atleast on the atvs.
In Comparison with the post of the 700 spark, I believe mine is sparking properly. I posted a YouTube video of mine. this leads me to considering 1. The fuel system or 2. Low compression. As my compression is only 50, I suspect it an issue, though it does run very strong when running — no apparent loss of power.I’d like to best understand how to chase back a fuel issue.
