P500 Steerimg wheel with buttons to operate winch
Red500
Red500
5,241
56,827
Greeneville, Tn.
Learned that a long long time ago when I kept melting switches for fog lamps in an old POS car I had.
Yellowbeast
Yellowbeast
64
111
Pennsylvania
I have been looking into the idea of adding a steering wheel with buttons or adding some buttons to the stock wheel. I would like to operate my winch with these , it would make it so much easier while plowing snow (along with the reverse lever mod)
The options that I have looked at so far!
https://www.amazon.com/Miller-Edge-C182-12B-Conductor-Extends/dp/B00NG1LKQS/?tag=sxsweb24-20
https://www.amazon.com/WINOMO-Momentary-Button-Doorbell-Waterproof/dp/B01N7QADKO/?tag=sxsweb24-20
Universal NOS Button Steering Wheel Black PVC Leather JDM Godsnow Horn | eBay
Motion Raceworks Opposite Side Dual Push Button Steering Wheel Bracket With Red/Green Buttons & Weather Packs
On a side note if u adjust the nuts for the reverse cable u can eliminate using it. I did and it’s one of the best mods I have done. I seen how to do it on this forum.
11,317
84,090
For you guys that plow, wonder if anyone tried hands free foot switches like those used for marine anchors/windlass up/down? Many options out there. Maybe mounted on board with disconnet plugs when not in use.
7B1B0510 997F 4013 B67F 0FBEA0B3CAD9
Chooglin
I looked at something similar but , I really couldn't find a spot to mount it. Another problem would be the amount of snow and ice that would get on them!
Red500
Red500
5,241
56,827
Greeneville, Tn.
Hey @Chooglin did you ever mount your switches on the steering wheel. How did they work?
Reactions: Chooglin
Chooglin
I have it on order from Amazon, I have not received it yet. It should be delivered this week , then I need some warm weather so I can work on it. I will post pics when I get it done!
Reactions: Red500 and trigger
Chooglin
My switch came in and I did a dry fit on it. I don't think it's going to work , the steering wheel turns almost 1 1/2 turns to lock. Not sure I want the cord wrapping around the steering column that much......... This is something I never considered!
I'm not throwing in the towel just yet but it's not looking good. A wireless switch would work perfectly, so maybe I will look into that !
Red500
Red500
5,241
56,827
Greeneville, Tn.
I wondererd about how well the cord would work.
Chooglin
Being that this is really intended for a boat , I know the wheel on a boat doesn't need to be turned much to turn a boat.
I am still going to try to figure out a way to make it work..........we will see!
Red500
Red500
5,241
56,827
Greeneville, Tn.
I hope to mount a winch soon so I'm hoping you figure it out too.
Reactions: Chooglin
11,317
84,090
Since just relays, What about some type of momentary push button mounted on paddle shifters? Fixed location, no rotation. Waterproof ones out there.
Waterproof Momentary Switch | eBay
A2CA2A87 A649 47D7 B087 45C3E5032858 327E3491 C1DC 4DC7 8868 E077C78140DA
Reactions: Chooglin
Chooglin
Since just relays, What about some type of momentary push button mounted on paddle shifters? Fixed location, no rotation. Waterproof ones out there. Or could drill out the + and - on paddles to mount.
View attachment 113379 View attachment 113380
I like this idea and would work great , only problem is , many times while plowing snow , you are turning the wheel while operating the plow up or down. The buttons need to move with the wheel.
Chooglin
I think I found the solution , it's called a slip ring. They make all different sizes with different wire configurations. I need to find a 3 wire that is a low profile (pancake) style. If I can find one that will fit under the steering wheel cap , this will work slick as s*** !
JCart
JCart
897
2,024
Kamloops, BC Canada.
Not sure on wheel switches would work for me... I have the winch plug installed bottom side, central dash and hook up the wired remote that has the momentary rocker and carry that in my right hand for ploughing. Momentary rocker seems small enough that I can still shift, steer and operate winch at same time.
I was thinking of one of those old school single post spinner knobs mounted in the bottom spoke of steering wheel with E steering would be cool for ploughing. Remember the ones on loaders that you could hit a side button and it would pop up to use the spinner or push it out of the way by rotating the knob inside the wheel radius? Hmm maybe I’ll see if I can find on.
Reactions: Mudder
Chooglin
Can't say that I've seen one of those , post a pic if you can find one.
