P1000m5 Sub trans oil getting into engine oil
208,731
Engine oil pressure isn’t squirted against the rear main seal of the engine in your Toyota, I don’t know for sure, just speculation. If the sub trans oil level sits at a higher level when sitting idle, fluid could transfer
I don't like my Toyota, want to buy it? We are talking about a P1 here, the sub trans bolts directly to the motor / transmission and that runs with a positive pressure, I don't know the pressure, but would bet it's above 30 PSI, I wouldn't think gravity would come into play???????
Rebelyell31
21
11
Florida
Checked the vent line all is wide open so I don’t know if going to keep a eye on it and then have to take it to Honda and see what they say
208,731
Ouch the Honda shop here I bought ours has a shop rate of $ 129.00 per hour. By any chance is it still under warranty? I wonder if it would be safe to do a pressure test with two gauges add pressure to the sub tran and connect a gauge up to the crankcase and see when you add pressure to the suborn it shows up on the crankcase gauge?????? Very low psi???
Reactions: joeymt33
Rebelyell31
21
11
Florida
yes it is still under warranty so it will be going to Honda shortly so they can give me the run around cause they ain’t got a mechanic smart enough to figure anything out on there own had a 700 pioneer should have keep it had zero problems out of it and with this 1000 it’s always something
TheHoover
TheHoover
221
694
PNW
hondasxs.com
What’s wrong with your Toyota? I have two, the V8 4Runner and TRD Tacoma. Love them both. Both are 2005s.
Reactions: CumminsPusher
208,731
My 2017 Tundra is a gas hog, 10 mpg with our S X S in tow and 13.1 empty? This truck is going to go! The way I drive I need an oil burner! HA!
TheHoover
TheHoover
221
694
PNW
hondasxs.com
Damn. That’s pretty bad. I need to upgrade my tow vehicle, I’ll take the Tundra off the list haha.
Reactions: sharp
208,731
Yea! It's a pig! A bad performing pig, my 2014 Chevy would out pull it at speed! The Tundras suck!
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
Maybe you got a dud... my 5.7 '08 Tundra Crew towed great. I wouldn't have minded the s***ty gas mileage so much if they'd put a larger gas tank in it. It supposedly was a 26.4 gal but with the low mpg it felt like it had a sedan sized 17 gal tank... now there's an option for a larger 38 gal tank.
0860silverado
959
1,848
louisiana
Just get an old Dodge with the 12 valve Cummins and be done with it. 22 MPG pulling a trailer all day long. And they sound sooooo good! No DEF, no particulate filter garbage, no problems.
208,731
YEP, stopping every 220 miles was the pit's Take Over trip!
208,731
Mine pulls good, just not very long, HA!
russknight
russknight
1,910
7,511
Perry Florida
Led5
Or just get one of these. 6 mpg but it has a 100 gallon fuel tank.
Neohio
Neohio
Beast of the East
21,539
91,165
Painesville Ohio
Can you share a little more info on the ownership of your machine?
What year?
Buy it new?
Dealer serviced?
Self serviced?
Mileage?
When did you notice this issue?
Reactions: tjoreo
208,731
GREAT! Let us know what's causing the issue.
russknight
russknight
1,910
7,511
Perry Florida
Wonder how it drives at 70-75 MPH? HA!
It will run about 65 mph with 16:00-20 tires (53" tall). Allison automatic, Cummins turbo diesel, AC, power steering, with air brakes. It actually rides pretty darned good on the highway. Offroad is a different story....
322,785
Gotta agree;)
