I’ve got a 2018 1000-5le. It has 141 miles and I just have a few questions for the pros.
Is it normal to have more resistance in shifting with the engine running vs when it’s off?
is it normal for Low to be harder to get into? Seems it has to be put into to Low with a bit of conviction.Only with engine running. With engine off, all gear positions and movement is easy and locked in.
Is it normal to have reverse creep to the point of having to hold the brake? H has a little creep but a pebble will stop it. Low is the same, some creep but the brake is not necessary to hold machine.
First service was at 90 miles. Running Honda oil and filters. Absolutely zero hard miles. Gravel, dirt, highway. Stays in low unless going over 20.
