I’m a believer in more sidewall!Oh, it's gonna happen man. It's not a question of "if", but of "when"..
One of the wheels I like is the No Limits Vector.. problem is, they only make it in 15".
I am too! I don't plan on lifting it, and am going to run 28's. I'd feel a lot more confident sticking with 14".
No I don’t want all the added weight at the top most part of the machine. Except for interior light and roof everything will be gone from mid section up. Going to build some enclosures down low and kill off speaker bars. No upper weight anymore!You going to make your own cage aren't you
Can't wait to see itNo I don’t want all the added weight at the top most part of the machine. Except for interior light and roof everything will be gone from mid section up. Going to build some enclosures down low and kill off speaker bars. No upper weight anymore!
I do believe factory cage is strong enough where we ride because of the trees. It took this hit very good considering it was already damaged. I’ll probably fill the cage with structural foam, done that before.
Plus I have full enclosure built around that cage. I think I can do some adjustments though to lower the cage even more. Going to try to do a slight curve in windshield as well.
Considering what she looks like now me either! It will take a bit. Still fighting with the tough parts, cash and time lolCan't wait to see it
Seems like one or the other isn’t too bad but both at the same time is impossible.Cash and time two hardest things to come up with .I hear yeah
That's the way it is when your making one you don't have the time ! When you have the time your not making the otherSeems like one or the other isn’t too bad but both at the same time is impossible.
That’s the truth! Gotta save when you can and work while you canSeems like one or the other isn’t too bad but both at the same time is impossible.
Sounds like you may have to make some modifications to your custom cab to support your new vision.No I don’t want all the added weight at the top most part of the machine. Except for interior light and roof everything will be gone from mid section up. Going to build some enclosures down low and kill off speaker bars. No upper weight anymore!
Some yes. Not starting over thoughSounds like you may have to make some modifications to your custom cab to support your new vision.
Can’t wait to see what you come up with! I was thinking about how your custom cab was fitted to your cage and how you would have to duplicate your cage mod to get an exact fit. I do like how your vision changes to support usage overtime and it’s not just about looking good, although your builds always have!Some yes. Not starting over though
Thank you old friend. I know what I want in this machine I guess it’s just a matter of figuring everything out. We all want things a little different and set up for what’s needed. To a degree everyone here has a little different rig based off thier needs. For us right now we need a dependable comfortable ride that goes anywhere but most importantly comes back. We will be out a lot more this winter so the enclosure needs to work with the machine. Last year when we walked out of the woods cold during the snow storm sucked. I don’t want that again. We need a year round machine that’s good in all terrain. So hopefully this’ll be better in the winter and summer.Can’t wait to see what you come up with! I was thinking about how your custom cab was fitted to your cage and how you would have to duplicate your cage mod to get an exact fit. I do like how your vision changes to support usage overtime and it’s not just about looking good, although your builds always have!
I surely don’t want to talk you out of new rims, here pretty soon I may be knocking on your door for the LE’s. I want those with red centers pretty bad
For a stock wheel I think they look really good.Yes, that is what I have and they are awesome!
