P500 Third blown engine
F
Fred-C
50
117
Constance Lake
Bought a 2016 p500 and within 800 km the engine had a “cold seize”. oil changes always done and dealer checked. Dealer fixed it and we agreed that he’d keep the machine, Honda did an extended warranty on it and I got a new one(still 2016). Second machine had the same thing happen at 4850 km. I had it repairedby dealer (new cylinder, piston, rings). Two days ago at 6300 km driving along a road and “baam), huge engine noise and we died. Oil was full and only 300 km old. I always warm it up to operating temps and it was 15C outside. Don’t know what’s wrong but I’m sure it’s not good. WTF? I look after my stuff and am, needless to say, super disappointed. Thoughts?
F
Fred-C
50
117
Constance Lake
We do ride some muddy trails but haven’t done so for months. I check diffs after we been in water but not a problem. Never submerged muffler ever.
Reactions: Biteme and Isaiah
NTCPrezJB
NTCPrezJB
President of #NTC
100,351
896,992
Canton, OH
Have you had water in the oil though?
Are you snorkeled? Stock air intake is about seat level (give or take a few inches) on the driver side.
In the three rebuilds...has the oil pump ever been checked? (Sounded like one was a brand new machine, but correct me if I'm wrong)
F
Fred-C
50
117
Constance Lake
The first and second machines were both brand new. Never been deep enough to submerge air intake. Don’t know if oil pump ever checked.
F
Fred-C
50
117
Constance Lake
Friends has a 2017 p500 That he treats like s***. 8000+ km and changes oil once in a while, but rarely cleans air filter and never checks/changes diff fluid.
NTCPrezJB
NTCPrezJB
President of #NTC
100,351
896,992
Canton, OH
So the oil pump could be suspect for Engines number 2 and 3 but not so likely to have been number 1 as well.
What's your intake boot like? (Thinking "clean" side of the air box) Running stock/foam air filters?
Have you had these machines on their side?
Any overheating issues?
Did the 2016 have auto mode? Are you running auto or manual? Anyone running these motors at redline consistently?
I mean drawing two bad motors and a bad rebuild just seems like if you didn't have bad luck you wouldn't have any luck at all.
JCart
JCart
897
2,024
Kamloops, BC Canada.
So weird and sorry for your troubles. How is the dealership to work with, like are they competent? Never heard of a Honda P500 giving it up (with out some mid-adventure) much less 3 to the same owner. Just wondering at Dealership PDI/repair if they have tightened everything down.... like air intake clamps. Hopefully post 3 is the charm.... if they repair again I’d be going over it with a fine tooth comb to ensure all critical stuff is as it should be. I’d check within your community to see if dealership are on top of if.
Say Safe.
F
Fred-C
50
117
Constance Lake
The problem with #1 and 2 were very similar; Cylinder, piston and rings replaced but nothing else.
we are running stock air filters and they have been regularly inspected and replaced when necessary. I don’t tend to keep something suspect, I’ll just replace it.
Second machine was on its side once in a slow tip over. We were with a number of people and righted immediately. Only damage was a small dent on the side and my ego bruised.
2016 is paddle shift only. I have taken it up to top speed probably twice ever. The only other close to redline would when I am getting bogged down/ stuck and I have to give it the gas to get moving. I’m the only driver and Im a retired guy.
F
Fred-C
50
117
Constance Lake
Say Safe.
the owner of the dealership has been very good to me, but I’ve also spent Can$40k there between sxs, sleds, saws, etc.
dont have a ton of confidence in his one mechanic.
heard from the dealer just now that a valve broke, entered the cylinder, punched a hole in it and the rest is nothing but bad news. Complete motor failure. Getting a quote for me but I think I’m done with this. very unhappy and hugely disappointed.
  • Wow
Reactions: Biteme
F
Fred-C
50
117
Constance Lake
Engine is toast. Valve broke off, entered cylinder, punched a hole in it and blew up the engine.
  • Wow
Reactions: Biteme
5,023
22,429
As another retired guy and knowing how I treat things, I'd be really disappointed too. The whole point of buying a Honda over its competitors is its reliability. :( As a solo rider, a breakdown would be really bad juju for me.
F
Fred-C
50
117
Constance Lake
You’re bang on. I don’t ride alone, either with wife and/or dog. When we ride it’s pretty remote. I happened to be on our about 1 km from home so getting back was not bad, but if on a ride that’s just us, I could be 20 km from home with likely no cell signal. Plus try to get machine out? A nightmare.
Russ989
Russ989
22,565
146,497
Well somethings wrong, that doesn’t just happen. Wrong oil, water in the intake or something has to be in play here.
bigshoe
bigshoe
421
1,425
These just don't blow up there's something missing here not one, not 2 but 3, just random dropping valves . these are one of strongest sxs, if not the strongest nobody else rides it , I remember how I treated my dads atvs
F
Fred-C
50
117
Constance Lake
I agree with you. Oil changed 300 km before this incident, changed by dealer. Machine never in water deep enough to get water in engine. Dealer says they know what happened, valve broke, entered cylinder, put a hole in cylinder and the rest is history. They don’t know why.
  • Haha
Reactions: Biteme
F
Fred-C
50
117
Constance Lake
In the first two I dont believe the valve dropped. That happened this time. Dealer said lots of oil in the top of engine so oil pump ok and oil was clean and full.
  • Sad
Reactions: Biteme and CID
208,011
He ever show a pic of his P5?
Reactions: Biteme
Test - Grid
