P500 Tire Size
11,316
84,067
Do you have width restrictions? Have 27x9&11 x 14, no rub but at 54 inches wide. If doing it again would consider 12 rims based on more sidewall as others have mentioned for more flex/smoother ride.
Reactions: deerXing
Splorin
299
838
Maine
Been researching the hell out of 28's lately. You'd be surprised, some tires that are high dollar just don't perform as well as you'd expect in some terrain. Love the idea of a meaner more aggressive tire, deep lugs and side wall protection but they start getting weighty and wheel speed is definitely a factor with this machine, especially with 28's. Carnivores are a good looking all terrain tire but you can't get them for 12" wheels.
My search keeps leading me back to the 2.0's, a light radial that wears like iron. Not great at anything in particular but good at everything and have never let me down. If there's another tire out there that can measure up, I sure can't find it.
Haven't decided yet on the 28's either. Like to take advantage of the 15's low gearing and clutch springs. When my 1000 screw winta tires come off I need to have tires ready to go. The 28x10x12 Blackwater Evo's (30lbs) are kinda my first choice. Have a set of never used silver/gray Big Bear SRA's that I can use that would widen the rear an 1.5" on each side. Kind of intrigued with 4 29x9x14 Maxxis Vipr's on some ITP A-6's(4-3) though. Not a fan of going to 14's but it's a little more sidewall (6-ply radials) and I'll have shocks to help out the ride. I'll need a rear spacer with that set. Fun crap that rattles around my head.....
NitroxDiver
NitroxDiver
488
918
Concord NC
I originally went with 25” tire and liked them but I recently moved up to 27x9x12 front and rear on 5+2 wheels. Still using the 1” front 2” rear spacers I used with the stock wheels. You asked for pros and cons of 26” and 27” tires. I think you would be happy with either size but here is my list of pros and cons.
26” or 27” tire Pros:
Smooth ride
More ground clearance
Lower engine revs at higher speed
Better traction ( over stock tires)
Speedometer is corrected ( at least it’s more accurate than with the 24” tires)
26” or 27” tire Cons:
Some power loss (but the P5 low gear handles it well)
Less stability ( easily corrected with wheel offset or spacer)
Jazzbo
North Carolina
I’m running 27” Rip Saw tires on 14” S. Storm wheels. No problems so far.
44B2F096 D7D6 4D79 843E F0A090F8CA03
Reactions: 1border4manu
WillyBill
WillyBill
Wheeling Addict
473
1,886
Clinton, Utah
  1. Talon X LV
I’m 600 miles into my 27” (27.75”) Bighorn 2.0s on 12”-2+5 ITP Delta Steel wheels. 11” wide on all four corners. Run 4.5lbs in front and 5 lbs in rear. Great ride. Stable as hell. Made it a totally different machine. I would definitely do it again. Looks mean, IS mean, rides waaaay better. power loss due to size is almost negligible.
JMHO...Your experience will not vary🤪
