P1000 Todd's 2018 Build
ToddACimer
ToddACimer
Pioneer 1005-2
3,554
14,578
Oshkosh, Wi
Made it to 650 miles today on the 2018. I love it. This one definitely drives better than my 2016. Today was our first trip out with the SuperATV arms and with the Elka stage 4 shocks installed. It was wet and sandy on the trails we rode and the shocks really were great. I'd say swapping from Fox shocks to Elkas was better than swapping from stock shocks to Fox Shocks. No more rattles and no more harsh impacts. I'm back up to 14psi in the tires which I like for aggressive riding.
IMG 20190928 112024
IMG 20190928 144846
66,188
View attachment 158100 View attachment 158101
I was wondering how the elkas were
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,554
14,578
Oshkosh, Wi
Compared to the fox shocks, the elkas ride smoother all the time, the machine no longer wallows through repetitive bumps and we never bottomed out either end all day. The roll stiffness feels quite a bit higher and the machine stays flatter in turns and has a lot less lean while off camber. In soft soil the rear tires chatter a lot less and nearly all the bed and door rattles are gone. With the Fox shocks I really struggled with low speed harsh impacts and the chassis feedback was always wheel hop or constant rattles in the body. At high speeds the fox shocks were pretty easy to bottom out even with just 2 guys in the machine. It's a lot better shock combination and all I did was set static sag based on the wife/kids and I on-board. Compression and rebound as still in the middle of the setting range.
All that being said the 300 lb single rate rear spring on the Elkas feels really good and that's what I had purchased for my Fox shocks. There's a chance the spring alone would have helped my previous setup tremendously.
I’m fixing to find out
208,011
I thought the Stage 4's had slow and high speed dampening, not rebound? My Stage 5's have all three, Ive got the compression set on the softest setting for trail riding with the wife. Enjoy your Elka's!
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,554
14,578
Oshkosh, Wi
They are adjustable for low speed compression, rebound and spring preload
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,554
14,578
Oshkosh, Wi
My Superwinch Terra 45 has been finicky lately about freespool and my expectation is that it's full of mud. I also came across a deal on a Warn winch bumper and a like new Terra 45. Todays project was pulling off the old bumper and swapping on the new bumper and winch. I'll tear down the old winch another day.
My setup to date has been the Terra45, stock bumper with bolt on tie downs and a Warn winch mount. The warn mount is a huge improvement in my opinion over my previous KFI mount but the access to the winch is still poor and seeing the cable is impossible.
IMG 20191019 143817
IMG 20191019 143842
Tear down
IMG 20191019 150222
Test fit, some grinding required to clear my upper a-arm gussets
IMG 20191019 153452
IMG 20191019 153452
IMG 20191019 153551
Pull test to stretch the new rope
IMG 20191019 171117
IMG 20191019 171613
IMG 20191019 171623
IMG 20191019 171628
Overall, I really like it.
Bad_bowtie
Bad_bowtie
Huge member
2,455
14,665
East Tennessee
Tear down
View attachment 162017 View attachment 162018
I really like that! I've got the factory bumper with KFI mount and Terra 4500. Your new setup is worlds better, I hate the way mine is currently. Aggravating as hell to get to the free spool!
20191006 171218
ehart814
ehart814
1,654
3,643
NWPA
The door and bed rattles being gone just made me very interested in Elkas.
Reactions: BWAF and ToddACimer
nitzo
nitzo
521
1,105
East Coast, Florida
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,554
14,578
Oshkosh, Wi
I added a few new parts today. 6" Rough Country light bar was first. I added it in the opening of my Warn front bumper. It was a perfect fit for the cut out.
IMG 20191102 192158
Next upgrade was to fix the gap under my Warn bumper. I remembered that I had tucked away a Warn plow mount in the basement. Turns out it's a pretty good fit for the gap.
Mount
IMG 20191102 194724
Gap
IMG 20191102 194727
Mount installed
IMG 20191102 204217
The plow mount is really beefy and the leading edge is all 1/4" steel. I think it'll make a nice frame protector and it fits well with my skid plate
IMG 20191102 204210
With the plow bracket installed, this really snowballed. I've been storing a 72" plow Warn plow for 2 years and today I had to check it out. It looks awesome. I have no need for this but it was a good deal at the time and someday I hope to have a driveway that needs it.
IMG 20191102 213654
IMG 20191102 213703
Russ989
Russ989
22,560
146,469
