P1000 Todd's 2018 Build
JiminAZ
JiminAZ
101
184
Phoenix, AZ
Would you mind sharing what threaded insert you used in post #46 to mount your switch panel on the dash? Getting ready to do mine and looks like you had a nice solution.
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
M6 nutsert. I like the ones from Astro Pneumatic
Reactions: BWAF
JiminAZ
JiminAZ
101
184
Phoenix, AZ
thanks. I don't have experience with installing Nutserts/Rivnuts. Have seen them used in metal applications. I was concerned about installation into soft plastic, but it looks like it worked just fine in the plastic. So they're OK for materials like plastic and fiberglass? I can see a lot of uses on both the Pioneer and my boat.
Wondering if I have to use a light touch upsetting the nutsert just enough to lock it but not so much that the plastic gets crushed or cracked.
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
They install just the same in plastic. If its thin or soft you can also just glue them in place after drilling.
Reactions: BWAF
JiminAZ
JiminAZ
101
184
Phoenix, AZ
OK thanks. I suppose by design they expand a controlled amount. I'll order one of the Astro Pneumatic kits. Been needing one of these for some time - I'm sure I'll find a ton of uses for it.
Reactions: ToddACimer
13,349
64,937
These are an option for mounting in plastic as well.
I tried standard riv-nuts and wasn't a fan.
Capture95
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Not new news around here but I added my under seat storage box today. Great mod. I cut the door for a better fit and it was perfect.
IMG 20200202 101216
Hole cut
IMG 20200202 103143
Cut out removed
IMG 20200202 103447
Door in place
IMG 20200202 124332
Door installed
IMG 20200202 124332
Door open
IMG 20200202 124342
IMG 20200202 103143 IMG 20200202 103447
56,719
Very nice, same way I did mine. Great mod!
BigOL3
BigOL3
2,994
8,918
Hole cut
Cut out removed
Door in place
Door installed
Door open
View attachment 181827 View attachment 181822 View attachment 181823
Dadgum, my door looks exactly like that but apparently is not the same size. I made the cutout on the interior side slap up against the raised portion of panel and cut the exterior side past where the joints overlapped, cutting into the plastic rivets ...... and it still is not wide enough. Were there 2 difference sizes of doors on Amazon?
56,719
Which one did you buy? I'm sure there are a few different size ones, but the link floating around here has only been for this one as far as I know:
1581024328656
56,719
That is the same one. Not sure how yall made the cutout without going past the rivets?
I had to cut just into the edge of the holes for my rivets. Looks like @ToddACimer may have put his a hair closer to the inside edge since he was able to keep the holes intact.
