P1000 Todd's 2018 Build
BrophyCreek
BrophyCreek
410
2,274
New Richmond, WI
Not on the trail. I have driven it at his place and motocross track and it moves. I'd love it if I owned it but I basically have a brand new Pioneer and it's setup really well for how I like to ride .
What dimensions did you use for the rear mesh panel. I like how you have it tucked into the tail gate.
Reactions: toddvdh
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
This is my order form from Covers and all. Keep on mind my roof is cut 3". Before I chopped the roof it did not tuck in the tailgate.
Screenshot 20210325 064957
Reactions: toddvdh
BrophyCreek
BrophyCreek
410
2,274
New Richmond, WI
Thank you for the info! I'll double check the height and may have it made a little longer top to bottom.
Looks like your on the opposite side if WI from me. I'm over close to MN, just North of New Richmond. Maybe meet down in BRF or somewhere in the middle for a ride some time?
Reactions: toddvdh
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
We ride in Black River Falls quite a bit.
Reactions: toddvdh
toddvdh
toddvdh
1,063
6,983
Green Bay, WI
Have you thought about doing a mesh mid panel so you can still talk to the kids in the rear seat?
I might try this.
BrophyCreek
BrophyCreek
410
2,274
New Richmond, WI
I might try this.
I have the hard mid panel and still get a ton of dust. Going to try to add the weatherstripping at the bottom of the doors. But thought I'd also try the mesh on the back to change air flow. Kids are older now, so usually on their own machines.
Reactions: toddvdh and TripleB
BrophyCreek
BrophyCreek
410
2,274
New Richmond, WI
BRF is a nice area. Haven't been down there in a couple of years. Usually go north. But want to get back down there.
Reactions: toddvdh
toddvdh
toddvdh
1,063
6,983
Green Bay, WI
We bought a second machine, so it'll be rare the kids are in the back.
I did the same thing. But last weekend the kids still like the back seat of the pioneer while my wife rode up front alone. :cool:
I guess it isn't dusty yet and they might change their mind an another month or two.
Reactions: BrophyCreek
JenElio
JenElio
64,244
602,745
Loxahatchee, florida
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Hey Todd how did you end up cutting the windshield? Thinking of giving this a try b4 the TO 🤞
This may sound really dumb but... I used an acrylic knife and the edge of the SuperATV windshield mount as a guide. I marked and drilled my holes then ran the acrylic knife over the edge for what seemed like 1000 times. Basically the knife scores the material and you take the material off 1/64" at a time til you get through the whole thing. My knife looks like this. I cleaned up the edge with a 2" sanding disk and a heat gun. It was not thrilling or glamourous.
JenElio
JenElio
64,244
602,745
Nice 👍
So you didn't have to mess with the notches on the sides of windshield?
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Nice 👍
You will have to match the profile of the original upper shape to clear the inner windshield mounts. I put zip ties around my struts to only allow it to open to horizontal as well
Reactions: JenElio
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
I ordered the PV3 harness ends from the club store to make room for my PV3 on the dash.
I think this turned out pretty good. 3m VHB and a Velcro cable strap on a piece of aluminum angle.
PXL 20210509 161335212
PXL 20210509 152311863
PXL 20210509 161328053
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Well RRB was an awesome trip. The Wildcat, Pioneer and Talon did great. I broke an upper a-arm bolt... Repair to come but it was just a quick bolt swap.
I also bent my upper driver door hinge. Got buried on trail 26. Had to winch for a while and the door hinge caught a stump. The hinge mount bent quick and easy fix
PXL 20210615 160939500 PXL 20210619 154805640 PXL 20210619 154808912 PXL 20210619 155148990
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
After yet another broken upper control arm bolt we are back at this again. I'm going to give the McMaster grade 12.9s a shot before additional effort.
Arctic Cat bolts for comparison.
PXL 20210623 233755763
Installed and torqued to 55ftlbs with red lock-tite and a jam nut.
IMG 20210623 183349 01
PXL 20210623 232931005
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Update on the upper a-arm bolts. I have been out twice since TN and have about 200 miles on the new bolts, no squeaks clicks or loose nuts. Maybe this is fixed.
On to new stuff. Ordered an HMF exhaust to get ready for the PV3 wideband adapter and a bit more tuning. Also ordered the quiet core but with out the quiet core it's quite loud.
PXL 20210905 202149713
PXL 20210905 220747993
PXL 20210905 230550483
Next up will be the rear Superwinch Terra45.
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
Cleaned up the old Pioneer today. It's been in the garage a few weeks and never really got washed after our last ride of the year.
PXL 20211226 234420634
Also fought the plow springs and replaced them with a bit stiffer spring.
PXL 20211226 220355306
Lastly made some skid plate modifications to get my tires off the center skid plate. At this point I have a little coil spring rub and a little a-arms rub at full lock. I'm not confident in front axle shafts enough to get on the throttle with this much steering input so I'll call it good enough for now
PXL 20211226 221919317
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,599
Oshkosh, Wi
I had a chance to look into the rear winch idea a bit more today. I stared at this predicament for about an hour. I can't see a bolt in solution and I wasn't motivated enough for a full weld in solution. With a few cuts on the winch mount, I think I can get above 1/2" of clearance to the muffler. This might limit total winch rope length to keep the rope cool enough and a bit further from the muffler.
Anybody done anything like this???
PXL 20211227 000641555
PXL 20211227 000652578
PXL 20211227 000649154
Reactions: Lady01 and TripleB
