When I pulled up to the dealer today to drop it off, a guy who went over the "how to" stuff came out and was looking it over hard and asking specs of the lift, wheels, and tires.
What size offset wheels did you get?? 5+2???Width measurments.
Front: 62.5"
Rear: 61.5"
Yes, they are 5+2. With the tires being a little over 9" wide it gave me the .5" They stick out a little on the front, but it's mostly the edge of the tire you see not the tread, if that makes any sense.What size offset wheels did you get?? 5+2???
I feel like I'm going faster than what the speedometer says, but I'm not for sure how bad it's off.If this has been talked about already Tot I appoligize but did you notice a difference in speed with the new tires and wheels? I ride mostly on the road and your set up looks like it would work for me. Awesome..
i took a ride with my buddy last weekend and we rode all day together his 700-4 and my p1k5 . we had diffrent miles outcome . he had 73 miles i had 71. we both went the same areas and same trails . i had the same issue with my honda rincon it was always slow on the miles compared to other machines.I feel like I'm going faster than what the speedometer says, but I'm not for sure how bad it's off.
Are those Grim Reaper tires bigger than stock?i took a ride with my buddy last weekend and we rode all day together his 700-4 and my p1k5 . we had diffrent miles outcome . he had 73 miles i had 71. we both went the same areas and same trails . i had the same issue with my honda rincon it was always slow on the miles compared to other machines.
Same size as stock. much better wheel guard at front . the rubber actually sticks out past the rim unlike the Horn'sAre those Grim Reaper tires bigger than stock?
They should rear the same on the Odometer, unless they measure more true to size than the stockers did.View attachment 12405 View attachment 12406 View attachment 12405 View attachment 12406
My 30" Evos with 10psi measured almost exactly 28" yesterday. Let us know what those Roctanes actually measureJust ordered 28x10x14 Roctane XS. Hopefully they will be here Thursday.
Will doMy 30" Evos with 10psi measured almost exactly 28" yesterday. Let us know what those Roctanes actually measure
Curious how tall they'll be mounted. Mine will measure 30". If I run 36lbs of air in them lmao.Tires just got here and they measured 27.5 unmounted.
With 18 lbs of pressure in them they measure 28 on the dotCurious how tall they'll be mounted. Mine will measure 30". If I run 36lbs of air in them lmao.
