P1000 Tough country front bumper in production!!
Tot
Tot
661
462
Des Arc, Arkansas
Very easy. Couple heavy brackets that bolt to the outside of the frame mounts, then 2 more at the bottom. A couple mounts for the plastic shroud too.
Waylan
Awesome thanks! I emailed Michael this morning and he said he would check to see if they are ready to ship on Monday. UGHHH I want this thing so bad!!!!
Tot
Tot
661
462
Des Arc, Arkansas
Waylan
Is there any difference in the way it rides with the bumper on the front?
Sent from my SM-G900V using Tapatalk
walexa07
walexa07
396
380
Louisiana
I added spacers to my shocks before I even drove it with the front bumper mounted. With the spacers added I can tell no difference. Went on a 60 mile ride this afternoon and everything was great.
Waylan
Reactions: Tot
Tot
Tot
661
462
Des Arc, Arkansas
Waylan
Thanks man. There was a guy on the Facebook page wanting to know
amc019
amc019
480
592
Little Rock, Ar
Waylan
Where did you get your spacers and how much lift did they add? I would like to add like 1" to just the front of mine to actually get some of the lift back I lost from the CATVOS arms
walexa07
walexa07
396
380
Louisiana
I got the street rays off eBay for less than $30. Since I added the bumper at the same time it's hard to know what they added exactly but they did add some even with the bumper.
Waylan
Reactions: Deltamud and Tot
ghost
ghost
993
1,873
BC
Yeah - that really changes the personality of the p1K.
With 85 pounds up there - how does the ride feel?
Edit - forget it see you answered that.
walexa07
walexa07
396
380
Louisiana
With the spacers added at the same time I could tell no difference - if anything the spacers over compensated and it felt better than stock.
Reactions: Tot and ghost
Wheel spacer should actually soften the suspension by adding distance from the pivot point on the frame. Of coarse the 85lbs will soften up the front.
Does anyone know the weight of the stock bumper and the Honda optional bigger bumper?
walexa07
walexa07
396
380
Louisiana
I actually like it how it is now. Was actually a little to soft/mushy stock.
Reactions: Tot
Kilo427
Kilo427
1,543
6,439
Can you post a link to which spacers you bought just ordered this bumper would like to be prepared. Thanks!
Deltamud
Deltamud
100
70
Florence, MS
What's your thoughts on restricted air flow to the radiator?
Kilo427
Kilo427
1,543
6,439
It will be here Tommorow so I'll be able to run it and take flir footage with it on and off, if needed I don't see why we couldn't open up some spacing by machining some vents in the bumpers. I really don't think it will be very bad but we see.
Reactions: Tot
walexa07
walexa07
396
380
Louisiana
My radiator fan didn't seem to run any more often than before, even though the ambient temp was slightly higher on our 60 mile ride Saturday. BUT I'm not one of those guys that buries it in mud either.........so I can't speak to all scenarios.
Waylan
Reactions: Tot
Kilo427
Kilo427
1,543
6,439
Pretty simple install, don't have spacers on front yet but I do like it!
Image Image Image
Kilo427
Kilo427
1,543
6,439
Aaa and yah know what.... We'll see that little spacer (black rectangle piece sitting in the hood) well I'm gonna need that... To go behind the bumper, so gonna take it back off.... And I'm just gonna sit down these tools for the night and slowly back away...
walexa07
walexa07
396
380
Louisiana
Looks good. I've looked at your 3 pics half a dozen times but I can't see which spacer you are talking about. Which spacer is it?
Waylan
Kilo427
Kilo427
1,543
6,439
Oh it was the spacer that sits in where the top two forks of the bumper slid into, I didn't end up having to remove the whole thing though it was late i was not thinking clearly. The beer had nothing to do with it I assure you.
