Tram's Ranch Limo build
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I have been kind of looking for one of these since i went with @Hondasxs to Montana for the unveiling of this machine.
Picked up this 23 1000-6 a few weeks ago. I needed to reduce the number of Hondas i had ! So I traded the 2 seat Talon X and sold the 17 P1k LE to my son who needed a sxs. So, I found this at a good price and jumped on it.
It had 650 miles on it and a few add-ons.
Full Honda one piece windsheld
52" curved light bar
Boss sound bar
Rear veiw and some side mirrors
Soft rear panel
20240724 085558
Today I did a couple things that I feel are must dos to the Pioneers.
RB3 door bushings
SATV flip up windsheld
Winch mount ( reusing the rear mounted winch from my LE.)
This is going to be a work machine, so I will likly add some rear and side work lights, a dual battery (or full size battery conversion) and a couple 12 vdc waterproof plugs for sprayer and power at the rear seats.
TimG
TimG
OLD SKOOL
795
4,008
Southern Indiana
Boss sound bar
Soft rear panel
RB3 door bushings
Very nice ! I want one !
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Well today I started a couple of mods on the Ranch Limo.
Installing a set of Atlas( SATV) forward A arms so I can run 30"s.
Installing a SATV full skid plate.
Here's a few shots of the swap.
I will do an in dept thread on the installation.
20250419 102335
20250419 102349
20250419 103120
20250419 103138
20250419 083858
20250419 093448
20250419 100627
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Finished up the Ranch Limo's SATV skid plate install last night. I think it turned out pretty darn good.
20250422 074630
20250422 074658
20250422 074643
As you can see it's fits really well and smooth on the bottom.
The normal install you would use approximately 20 tek screws for the spots that are not factory points.
20250422 075717
I chose to drill and tap all of these screw holes. I will check the fasteners after my first test ride. If they do not hold i can go back and install rivnuts and re anchor. I also reused a few of the OEM bolts in the places they would work and have a full bolt thread through the factory nut.
Overall the install was straight forward and not to difficult when you have access to a care lift.
7,608
31,549
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Next mod complete!
Added OEM LED headlights to the Limo.
It's awesome when you have a buddy that updated his Talon headlights and swapped you for his OEM.headlights. This may be the only crew with OEM led headlights.🤔
20250422 134129
20250422 134245
20250422 135447
20250422 135757
20250422 140621
20250422 144407
20250422 151752
20250422 151831
20250422 151835
