does anyone know if there is a speed limit you're supposed to stay under when in 4WD (not diff lock)? I was riding in my new ride out on the outer banks this weekend and noticed a strange sort of grinding noise almost like the the noise it makes jus before and as the transmission shifts, but it wasn't shifting. It seemed like it was at a point where it probably should shift, sort of at the edge of the rpm range where it would normally shift cruising about 25-28 mph. Just didn't know if I missed something saying don't go that fast in 4WD or not. Anyone else have this or know what it may be? Only things I've don't to it are the vent hose extensions and heat insulation under the seat. if I were to take it to the stealership should I put the vent hoses back and take the insulation off?
Thanks
Thanks
