P500 Transmission slipping or rear end???
T
tylerj738
Louisiana
When I brake hard I get a sound coming from the machine that sounds like gears grinding. Haven’t been able to pin point the location yet but it sounds really bad. It only happens when braking hard. It does in in Manuel and automatic. It’s a 17 with 700 miles and is new to me. Any ideas what it’s from and possibly how to fix it?
Reactions: Biteme
42,986
Its probably the normal rear brake noise. 700 owners are familiar with it since it has virtually the same rear end. It's never seemed as bad on the 500 too me, but it's smaller, lighter, and low geared, so you don't have to use them as hard.
Could also be pads gone or a stone lodged in the caliper.
Reactions: Biteme
Lilred500
Lilred500
Keep it on the rubber side
548
1,997
Wv
My brakes have done it since it rolled off the lot I think it’s nature of the beast
Reactions: Biteme and DG Rider
T
tylerj738
Louisiana
Thanks I will look at that today.
Reactions: Biteme
G
Gassygordo
302
1,025
Fillmore, NY
My 17 has 3100 miles and I don't get that noise anymore,
T
Tstover
141
398
Central PA
My ‘17 has 2200 miles and sounds like it‘s going to explode under heavy braking. I’m used to it now.
futzin
futzin
4,131
30,685
Kentucky
I don't think I've done a hard brake yet!
Reactions: trigger
178,016
Haven't found it necessary on this machine either, braking at all for that matter. The low gearing works as the brake in most situations, you still get some rear end clatter but not terrible. I've been questioned whether my brake lights were working because they're rarely seen.
