P1000m5 Traveller II
2016 Honda Pioneer 1000-5 Deluxe
I found a leak on the other end of that myself Sat.
That looks like the front of the rear driveshaft? That is probably grease slinging out of the joint. Mine is doing the same thing but after inspecting it, I found out it was not oil. It worried me enough that I started keeping a closer eye on the engine oil level.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
It is...i noticed it awhile back ..it doesnt drip. Just stays moist enough to collect dirt.
tramguage beat you to the patterns. He’ll sent them to you when he’s done I would think.
It’s like herpies. One person receives it then passes it onto another, pretty soon it’ll spread across the site. All started with Joey thinking something was hot
I haven’t updated this in a while. Not many changes lately except for one big one. Added the IGR a few weeks ago. I love it!
It makes pulling the 32” Terrabites a breeze. I only took one pic of the install.
D9561a94d981436ec42efa8c9678e43d
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Did you do the clutch cover update too?
Time for another update here, it’s been a while.
Added 3/4” bars to the OEM crossmembers plus two additional for support. I’ve had the OEM crossmembers bend straight up where they were very close to the oil pan. I’ve had to pull them down twice. I have also had the plastic skid plate touching the shift lever. Hopefully this doesn’t happen anymore. Stock is 3 crossmembers and now there are 4 total but 3 of the stock were reinforced.
7d23990064fe24a23510830098e9f475
Had to cut the corners off to sit flush
1a8b20a2e2c1df035012da705385d32f
3a92136dac4e5d9c55a75f7f388d3055
The TIG crapped out on me so I used the flux core wire.
87a9a8d80c5c2aef173575d27b58bcf9
E953824902491b14502f0ff3c08a8f33
This is one added to fill a large span that’s not protected. Not pictured is one further in front of that OEM crossmember.
B71f17ff0bbfc77e02c3d37b3b1ba36c
Maybe you can see under the skid plate the forth attached to the front of the OEM crossmember.
6852d54e9cd3fddc4a8c38549170db21
281,031
Underbelly reinforcement is really needed in the rocky terrain, even just crossing down trees. Good idea.
How much weight do u think this added?
Would a thick wall tube work just as well?
I know mine needs to be done.
Maybe added 10lbs?? Not sure but it’s weight down low so I don’t mind. This is not mild steel either. it’s 1080, very strong and rigid like high quality knife blade steel. It can be brittle when thin like a blade but it is very high strength against permanent deflection.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Thats something ive been meaning to do. Especially under shifter. Nice work man
I found a crack in the paint after doing my inspection after the Overland trip.....
Can’t see it in this pic but it’s 11 o’clock from the steering boot
92b2dcfe7d1e0c4bd92bbacc4b1da9ec
Close up pic...
5aec4438817c88376271c8af8dafde33
Even closer pic with chemical paint stripper....
D8e218816942641e4454497f4a3c2b82
Similar threads
Hometeam
Replies
Views
2K
Hometeam
