????The propane tank trick totally rocks!! Some of my rubber didn't stick completely to the aluminum. At speed it doesn't matter. The rubber is pushed flat against the metal by the very air it's keeping out lol. Thanks for the tips!!
Do you have to haul the propane tank with you all the time/ HA!The propane tank trick totally rocks!! Some of my rubber didn't stick completely to the aluminum. At speed it doesn't matter. The rubber is pushed flat against the metal by the very air it's keeping out lol. Thanks for the tips!!
I try to avoid flammable things!Strap it to a propane tank with a ratchet strap and it will be bend and conform to the same curvature as the propane tank.
We all remember why lol
No facial hair,sweats or cowboy boots...it's not meWhen did you start wearing that purple and white trucker's cap CP?
You don't have nose hair and ear, don't worry you will, HA!No facial hair,sweats or cowboy boots...it's not me
Then I finally got around to installing the SS brake lines from @jak9922. Really nice kit. It came with everything needed. Easy to change.
I upgraded because of recent failures at the Takeover. Those had me worried. Then I saw this cut in one of my lines...
No need to worry anymore, these lines are stronger, moved to a new location so they don't get pinched by the tie rod, and they're a little longer. Longer is better as the stock lines were stretching a little with the lift kit.
It's just an added bonus that the brakes feel tighter now. They are great!
Thanks Jak
glad you like themThen I finally got around to installing the SS brake lines from @jak9922. Really nice kit. It came with everything needed. Easy to change.
Thanks Jak
