P1000m5 Traveller II
Ac240df1c2fe35d8a8a5be85c6e90f10
13,418
65,791
Not having seen the back of a panel in quite some time, but I would bet you could take a piece of sheet metal, bend tabs in it and pop rivet it into place on some of the back side webbing. or if you don't mind drilling the panel, couple pop rivets thru the face.
Reactions: sharp
13,418
65,791
Just looked at the backside picture you posted. Can you insert some dowels into the reliefs molded in?
Reactions: sharp
They need at least a couple mechanical fasteners to keep them from blowing off if hauled on an open trailer or from being rubbed off in the woods. Even though that last one really is a good time!
Reactions: joeymt33 and sharp
13,418
65,791
Honestly, either the velcro or @snuffnwhisky suggestion to tig a wingnut will be the cheapest easiest solution.
I’ll try the Velcro and use two thumb screws per panel for just incase.
Now how do I make the hook and loop and stick to the plastic reliably thru winter and summer? Use adhesion promoter? Of coarse it needs to be scuffed.
Reactions: sharp and JTW
13,418
65,791
Give some thought to either pop riveting a piece of sheet metal to the door and stick to that, or scuff door, clean with alcohol, apply velcro, pop rivet in place?
Reactions: sharp
It would be easy on the door because I can reach behind. I can use some washers on both sides of the rivets. Not so sure I want to do that on the color sides of my vehicle because they look so pretty!
D245719ad0701fd1eb7c8bab623ff732
Reactions: sharp
13,418
65,791
What if you scrap the velcro idea?
Grab a piano hinge, and hinge the red near the ROPS in the above picture? some nice stainless button head screws shouldn't look too tacky.
Drop of red loctite on a 10x24x1/4"-5/16" screw and run the nuts on. pop rivet or use screw on door.
Or bolt from inside out and use acorn nuts or nylon lock nuts?
Reactions: sharp
I thought about the hinge but I would only be able to use about 2 inches of it or there would be a lot of the hinge visible. There’s just not a flat side to use it on.
Reactions: sharp
Similar threads
Hometeam
Replies
Views
1K
Hometeam
