P1000m5 Traveller II
Ac240df1c2fe35d8a8a5be85c6e90f10
13,418
65,787
Capture8
Can you hinge on the bottom straight piece?
Reactions: sharp
Finally got some time home and finished this project. Well, almost finished. Still waiting on the thumb screws. I’ll do 2-3 per door and that should be enough.
Passenger side panel. If someone cared they could color the rivets.
Feb3946cea7ec48f3e279531ba9cd118
Rivet up top for the chain.
26faed99bd9a2ac0de92f0f76948c574
Not too bad.
8194ec87f6b0ef3fdee4eb8cb6109e26
This is what I fit in the passenger door.
86e6b9399b3b6f4d03acb0c97ad19635
1c6bf8d5fb5bd0191766cc32bc1d57c6
Driver side
50cefe10c1b5644b44cbd3323a20298d
Thoughts:
It’s easy to get to. In the past I was required to remove ratchet straps or bungees that held the boxes down in the bed. Now it’s just a couple thumb screws and dig for it.
The hinge needs washers for backing inside the door.
The hinge needs spacers between the colored panel and the hinge. I used some small #10 nuts.
I bought 10 thumb screws. I’ll keep extra in the glove box. Extra could be used for trailering.
sharp
sharp
3,757
14,955
Tennessee
Thoughts:
I would double bag the toilet paper.
13,418
65,787
Happy to see the piano hinge worked!
How is the door function/swing with the added weight?
Reactions: pct
Thanks for the input, it works great.
As for the added weight, it’s no problem. The Honda hinges are beefy and actually the door now sounds more solid. Time will tell if it causes an issue but I doubt it.
Reactions: pct, Koda and sharp
The thumb screws arrived. I think it will work good. I bought six, two for each door and two spare in the glove box.
0ca786729c37c6e67cb9556e5a4f451e
I cut some of the screw off so I didn’t have to thread it so far. Then I used a shoulder nut so it captures the plastic.
Bf86c84d17271cd4b5a81c216b8570b7
The shoulder nuts have loctite on them.
Here is the pieces I bought. I thought these would have less chance of hanging since they are round versus a wing nut.
D4d57c9b120cb948721e84b5cc3cf4da
The 16mm length would be better as I had to cut the 20mm length.
E
elkguide
3,377
7,963
Vermont
The shoulder nuts are have loctite on them.
Come on now joey.
You wouldn't have been happy if you had something that you could use "right out of the box!"
Just an update:
So the rear door storage is working out great. Definitely a worthy mod for those interested.
Also, I upgraded the wetsounds 6” to the 8” sub. It was an eBay find said to be a display unit. Sounds a little better and still fits with the dash storage kit.
C25e3c3ea1117bc308003a2e4f1ef68e
I called my local dealer and got the clutch update parts on the way. Hopefully it will be here early next week. Also called Reduction Boss and put my name on the waiting list for the IGR.
This should be a fun month in March!
Similar threads
Hometeam
Replies
Views
1K
Hometeam
