I have noticed similar paint cracks on all my a-arm weld joints but nothing on the frame itself. I'm not sure how well the paint adhesion is on Honda's parts but I'm also curious if the heim joints on your a-arms carry the load into the frame and if the Honda bushings on the stock arms may absorb some of that load.
Delton was stock... and I’m pretty sure the others have been also.The heims May have more impact but the Oem hinges don’t move freely so they are constantly pulling up and down. I’m not sure which is worse because after 3000+ miles of using these joints I can’t say I’m unsatisfied with the way the machine has held up with the abuse I have given it. Especially with my front 5” wider than stock.
Actually the Heim joints are only on the bottom and the upper is stock set up. But I have seen some paint cracking on the bottom in the past and had to re-weld those areas. But I never used any gussets. I know there have been several members of the forum tear the a-arms from the frame but I can’t remember if any of them were using stock a-arms and bushings. I know that none of them were using Heim joints.
It may be hard to tell in the close-up picture that I provided above but the Weld is pulling from the tube and there is a crack. But I’ve been wanting to strengthen up the front for a while anyway.
I need to do this this winter...The lower a-arm is strong in the back but the front of it can be a weak point too. I’ve had to weld stress cracks in the past on both sides. Snuff showdown me the modification he did and I copied it.
Nice work Joey.
I need a little shop therapy..but my new shop is an awful mess.and dark as a dungeon..Thanks bud. Shop time is therapy for me. Who’s next?
Yessir...brown truck.is makin daily runs.That’s not fun. Sounds like you’ve got some winter projects coming up.
Is this a common enough problem that I should talk to my machinist about making 10-15 sets?
I'll model something up today then.I think you’d find 10 people who’d buy them.
