P1000 Tried and true cab heat fixes-2018
OnTheJob
OnTheJob
426
925
Bristol, NY
Thought I saw someone mention removing some of the engine cover panels helps disperse some engine heat. I'm guessing that may only apply to the 3-seater.
Reactions: ohanacreek and BWAF
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
I have not found a fan no bilge pump that will last more that 1 or 2 rides under my seat I just gave up and sit a cooler in the middle with more cold beer.
Your fans keep burning up?
Anyone else have that problem?
Reactions: BWAF
mjn
mjn
1,409
5,206
I do not work for and am not affiliated in any way with YETI products or company but dang, when it comes to keeping stuff cold for long periods, these products cannot be beat IMHO. The little 20-quart cooler weighs a ton (even when empty) but gets the job done line no other I've found. Throw food/beer and ice in that thing and you're good for three days.
Yeti, Engel, and a few more brands are all pretty dam good at holding ice. We have a Yeti 105, and just picked up a 20. Both are amazing.
The 105 sat in the bed of my Viking for 3.5 days on my Magruder ride. (early August... very warm)
Still had a bunch of ice when we got back to the trucks. Pretty impressive.
Reactions: BWAF
popeye
popeye
3,275
14,644
kapowsin, Wa
For what it’s worth, I had 2 of the cheapo amazon bilge fans under my seat for the last year and a half. They have been submerged underwater countless times, ya mine may not get ran as much as much as some of the guys in the south. But i think even if they were to go out on me on this weekends ride, for the price I would buy another pair
208,729
I'm officially a fan of the fan now, installed mine this evening, tried every thing else, it helped, but didn't cure the issue. I already had the fuse box, wire and connectors . Cost me $ 40.00 and it works great!
mjn
mjn
1,409
5,206
Smitty, if you wouldn't mind;
*What fan did you install?
*Pics of it installed?
*how noisy is it?
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Not smitty but here you go
*how noisy is it?
1st pic just 4" fan not much louder than engine fan D60bbe55c316cb50f57244cb6b7fbe7950048b293c2176237922cfc17705dc8e5527193529449b69b8bbc355756d0f270e17ec0af8e728413f77f6c298ddcef6Dfc9440f539114ba3c8be5d134847f66E0f713f24e10044395aee400a8e1fd538515bf65de69f9cbf40bc0ad99b696ad
208,729
*how noisy is it?
Just a 9 inch fan zip tied with manual switch, nothing fancy!
Reactions: BWAF
208,729
I should have took pictures,but i didn't . I coppied JTW'd in in stall
Reactions: JTW, mjn and BWAF
Poppaj
Poppaj
16
40
SE Oklahoma
Used a 8" radiator fan with thermostat, Plenty of heat insulation under the seat, and fabricated piece to cover the exhaust pipes. Check out the rear heat shield thread. Have pictures there. Be sure to wrap the exhaust pipes completely all the way back to the muffler and use dynamat on the bottom of the shield. Looked at the new design Polaris 1000 and they have a lot of wrap on their pipes, so it must not be a Honda-only problem that I thought it was. The shield was the last thing I did and it made as much or more difference than everything else combined. All is good now.
A-Team Performance 120021 8" HIGH PERFORMANCE 1700 CFM 12V ELECTRIC RADIATOR COOLING FAN - REVERSABLE FLAT BLADE 10 BLADE
Hayden Automotive 3653 Economy Adjustable Thermostatic Fan Control
Shinehome 6mm/236mil Car Trunk Hood Sound Deadener Deadening Heat Insulation Mat Noise Insulation and Dampening Mat Heat Proof Mat 40" x 40"(10
Reactions: mjn
RedFred1
RedFred1
301
619
North Carolina
Have you tested it on a longer ride? How well does it work?
To be honest with you, I do not go on long rides. The heat was mostly tolerable for me. While I was adding some other items, horn, back up alarm, winch, switches, etc. I made this mod as well. I found others who had posted this type of mod and thought it was the best route, so I went with it.
link to good video of one like it.
P1000 - OnTheJob's P1K-3 Build: "The Pie-O-Near"
HTH!
FredD
Reactions: BWAF and mjn
