Trigger heat shield review
66,571
Last takeover I won a 1000 heatshield. Well after a year I finally installed it.
Piece of cake to install. I use to run the silver insulation and would take it out in the winter. I can tell you after quite a bit of seat time at the takeover I was shocked at how well it does. I don't need anything else it's better than the insulation and a blige blower. Kids had zero complaints on steam ect. Great product @trigger .
TripleB
TripleB
11,761
100,011
Caryville, Tennessee
I knew it would have to help tremendously on the steam baths. Your machine is only one I've been in that didn't have the Honda update or anything else under the seat. It would almost burn you when you splashed a mudhole lol. JAH for ya.
Robobrainiac
Robobrainiac
2,460
8,569
Are you using the trigger heatshield? Or something else specific?
66,571
I did that incase someone stole it. I'd find them within 5 miles or 2 water puddles. I see it worked as you were the experiment. Now I gotta take the key out.
66,571
Looks nice and clean
20230610 184229
as well.
157,189
I know i should not ask because i dont know how to post pictures.But could you show a picture of the back.
This pic isn't a P1, it's a P7 but same concept. It follows the shape of the seat back at the top, actually the rops but... There are holes punched in the rubber that line up with the bolts that hold the seat back.
Stamp
208,013
I’ve heard nothing but good things for them. I had one in the P5 from one of his early batches. Definitely worth the price of admission
I believe it's a safety issue, I wouldn't let children sit in the front due to the steam issue. The Quick Shield takes care of the potential hazard.
Luka
Luka
29
80
Wittenberg, WI
Just installed the Quick Shield yesterday and took a long ride in north central Wisconsin. It was only 75 degrees, but this P700-4 Deluxe heats up quite fast. This heat shield made a huge difference in reducing heat and sound. The only heat we felt was a little through the slits for the seat belts. And we could talk to each other without yelling. The Quick Shield is well worth the investment, and so easy to install. Thanks to all who recommended it, and to trigger.
john790
330
1,021
Clinton ohio 44216
Well dont do that.I have a soft rear panel and was wondering if the rubber went inside the panel or outside the panel.Inside i would think it would let the heat back in.
Scoop
Scoop
4,252
15,929
  3. Talon R LV
I'd have to pull the 4 10mm bolts that hold on the backrest. But it basically goes up to the bolt points. Pioneer is tucked away in the trailer now.
Five.
Reactions: Robobrainiac
