P1000 True UTV-SBI-18 Smart Isolator vs Stinger SGP35 500-AMP Relay and Isolator
TxDoc
TxDoc
2,446
7,862
TEXAS 🇨🇱
photos.app.goo.gl
Has anyone had personal experience with both?
I have the Stinger installed and with my Battery Tender 800. Over time my main battery discharges and I can't start the motor. Checking the two small posts, one os a ground and the other shows 0 voltage. Guess the Stinger failed. I ordered the True as it gives a visual confirmation of activity.
Just wondered if anyone had nade the same switch?
67,234
Stinger has 2 uses.
1 - as a relay to power accessories. TrueAM can not.
2 - as a isolator to combine batteries like the TrueAm
Concerning #2.
The TrueAM and Stinger can be wired to do the same thing. Just the stinger will be manually opperated.
Question. And maybe i read it wrong.
But you say. "The small post has 0v"???
And it should alone.
You have to apply 12v from a battery source. Then the stinger "should" work bridging the large post.
Reactions: TxDoc
TxDoc
TxDoc
2,446
7,862
TEXAS 🇨🇱
photos.app.goo.gl
Stinger has 2 uses.
Concerning #2.
Are you using one over the other?
Sent from my XT1635-01 using Tapatalk
67,234
I am using the TrueAM for the battery bridge.
I have a common relay in my fuse block that works similar to the stinger for powering accessories upon demand. Key-on or off.
Reactions: TxDoc
TxDoc
TxDoc
2,446
7,862
TEXAS 🇨🇱
photos.app.goo.gl
If it's not too much time, can you draw me a diagram how your batteries and True AM and Stinger are wired? Thank you
67,234
Here is the basic TrueAM install.
When talking about all this. Dont combine the systems in talk.
- You have your dual battery system
- And you have your accessory system.
Talk about 1, And focus on 1. Not both in the same conversation. Then you will relize how simple the dual battery install actually is.
Adding a volt meter should be part of the accessory discussion later. As your choice of operstion will really simplify things... or not.
Reactions: TxDoc and TripleB
