P500 Tusk VS EZ Steer Power Steering
106,161
Has anyone done a comparison of the two units? I just installed the Tusk Power Steering from RMATV and it seems great so far, nor am I gonna switch it out but it was priced reasonably lower than the EZ model. I'm just wondering if I made the better or worse purchase. In photos, they both look identical. Thoughts? and thanks.
They both have high reviews
Tusk with 4.5 stars and 27 reviews Normally priced at $498
Tusk Electronic Power Steering Kit
EZ Turn 5 stars and 14 reviews Normally priced at $599
Honda Pioneer 500 Power Steering Kit
Reactions: RumpRocket
NTC/TAP Transition Member
11,834
90,079
Definitely look the same, either way is a good upgrade. Effortless one hand steering. For those debating a purchase, no regrets here. If it ever fails, would buy a replacement in a heart beat. 1 yr. so far, no issues.
Bad_bowtie
Bad_bowtie
Huge member
2,567
15,861
East Tennessee
That's something I wanted to do at takeover. A side by side comparison. Just so much stuff going on so I didn't get a chance. They sure do look to be identical though.
Power steering is one mod that I wish I had done sooner, and any future machines WILL have it.
193,166
It's about to for me, one more round. Plan to clean up all my wiring while the skids are off too. I was surprised how well the electrical held up doing the creek crossings and mud holes. I've had a second battery under the seat for over a year now and haven't had any problems.
DaddyDubbs
DaddyDubbs
15,381
145,192
Oh no, say it isn’t so...You’re such an inspiration to constantly spend more $$$ , Honda should put you on their payroll lol. Gotta be something else to add.
Looking forward to riding with you again at the Mac
Reactions: JWB and trigger
Bigdrag
11
5
Ojai
Installing tusk power steering as we speak. I have two issues. One the lower shaft is barely touching the plastic hydraulic reservoir. Any one else have thus problem? Also the wiring instructions say to hook the “”white” wire from the harness to the “brown” wire on the ignition switch. There is no brown wire? Help! Pioneer 500 2015
Reactions: rtn001
11,834
90,079
Have the EZ steer which is similar so will take a guess. Had to shift the mounting plate for free movement and clearance, so keep the bolts loose at first. If your brown wire is the low amp key-on wire, you might be able to tie in to the accessory plug lead if you don’t have the honda sub harness for key on power leads.
Reactions: rtn001
Bigdrag
11
5
Ojai
Right.. I cut a notch in the plate that allowed me to shift the bracket further to the left. That fixed the clearance problem. As to the Brown Ignition wire connecting to the white wire... I suppose I need to find the switched power lead coming from the ignition regardless of color?
Thanks!
Bigdrag
Bigdrag
11
5
Ojai
If you are near a dealer buy the Honda accessory lead. It will come in handy for future accessories and is less than $10.
Right. I don’t know the function of the white wire that is attached to the tusk harness. The instructions simply say attach it to the brown ignition switch wire.. but there is no brown wire? It’s s guess but I’m thinking all I need is a switched lead from the switch to allow the steering unit to receive power????
11,834
90,079
Second that, wished I had purchased the sub harness sooner, having those 4 key-on power leads is nice.
