P1000 Unpopular opinion: stock suspension isn’t that bad
69,996
After reading all the threads about the dumpster fire that the stock suspension is, I was expecting to hate my first time out in it. We’ve had it for a year, but the first 60 miles of its life was plowing our driveway.
Did 75 miles of trails this weekend and found it to be perfectly acceptable. There was sand, rocks, whoops, mud, gravel, and iron ore dirt. Most of the trails were in the 25-35mph range.
It’s a basic 1000EPS with Deluxe wheels and tires at 14psi (probably should drop a bit). I’m sure the suspension can stand to be improved upon, but I’ve been quite happy with the utility and fun factor of this machine. So if you just bought a machine and are planning out all your mods, I’ll go a bit against the grain and say you don’t have to rush into Foxes.
I agree. Especially going slow. My stock 1000 rode better than my 700 with walker Evan's did
Reactions: Haldog77 and Isaiah
Isaiah
Isaiah
2,191
6,964
Altamont TN
It rides like a Cadillac to me but I came from a 1998 foreman;) still room for improvement
322,797
If I had to do it all over again (and I have had to multiple times) I’d still get shocks. There’s a few other things I wouldn’t do and have already switched up but I’d personally still run Fox/aftermarket shocks.
Only problem I see is it’s now much easier to over drive the rest of the machine and continue to go through parts. Hard to build everything else strong enough to take hits if it’s driven to its added ability. Can and has been a viscous cycle.
If it were used for work/farm or someone wasn’t aggressive then the non-adjusts would be fine. Actually smoother at lower speeds.
bullyx
149
450
new york
I bottom my fronts out pretty easy, rides great if not pushed too hard or catch the unexpected rock or what not. Maybe my shocks are a little off from factory, whose to say unless compared directly with another machine on the same trail.
TripleB
TripleB
16,346
148,032
Caryville, Tennessee
My front shocks did the same thing. It was pretty harsh but I was coming from a honda four wheeler to the Pioneer. I thought it rode pretty good at the time. I went with fox shocks after a year and I can ride some pretty ruff trails at a good speed now.
Reactions: JenElio and Ohio4x4
