P500 Walker Evans shocks for P500
HUCK
HUCK
1,047
2,319
ARIZONA
Did ,,,,someone say ......old timer
Reactions: rocmar
mack63
mack63
21
31
ohio
I replaced all four of my shocks with WE last fall and it was worth the $1,000 I paid. I've only put 200 miles on them at Hatfield McCoy but the ride was much better. My wife barely had to hang on even riding at a fast pace. We were less tired after two days of riding then the rest of our group was riding RZR's.
As far as buying fronts only vs. all four...I noticed way less bounce from the rear end when hitting bumps at speed compared to stock rears.
Let us know your thoughts after you get some miles on them.
Reactions: trigger
Shadesmn
Shadesmn
505
959
Ramsey, MN
@trigger, so i too am growing impatient waiting on a reply so will probably call later today. Did you just ask for the forum discount then when you ordered?
Reactions: trigger
highpocks
36
29
prescott mi
Shadesman i called we and got the discount. i told them i emailed them about the discount and no answer. so he gave the discount. 4 shocks on the way
Reactions: Shadesmn
jay_man81
jay_man81
356
1,158
Central Pa
www.facebook.com
Man, I'm off the forum for a few days and miss everyones questions...lol. Sorry guys!!
You guys that are buying are going to really appreiciate them.
I may have mentioned this before but before the snow hit a friend of mine bought a P5 (left over 16') and we went for a ride. For kicks and giggles we switched just so I could compare the ride now that Ive gotten several hundred miles on the WE and have forgotten what the stock shocks were like. Needless to say...I don't remember the stockers being that rough...lol. So glad I got the WE!
I also had a hard time getting my friend to give me back my P5!
jay_man81
jay_man81
356
1,158
Central Pa
www.facebook.com
@jay_man81, maybe you would know, are the different colors for the different spring rates on the coils? And if so did you run the 200lb in your tests i dont recall. I do run a plow and wonder if the 200 might be better than 175 with the added weight from that even though its only seasonal
I did test 200lb springs but didn't film that part. Also did 225lb. When I did the 200's I added about 70lbs to the front of my machine to simulate a plow and they did just fine with the compression turned up on the high side. Around 8 clicks up from full soft. To me the 175's felt just a bit to soft for that weight and made the front feel like it was nose diving.
I know you already ordered so hope I didn't make you regret your decision if you only got the 175. The should still be find if you turn the compression to full stiffness and adjust the preload up a bit. The 200 just seems to be a better fit for plowing.
196,510
Told them ' I was a member of hondasxs and heard they were giving them to us at $249 plus shipping '. Said he didn't know anything about it then went and asked somebody. Came back and said ' yeah we can do that '. That's the deal you got too right?
jay_man81
jay_man81
356
1,158
Central Pa
www.facebook.com
A bit to me yes. Setting the compression stiffer works great when your wanting a stiffer ride during a ride but when your shocks are constanly compressed with the weight of the plow, the stiffer setting doesn't do much unless your plowing really rough terrrain that gives the shock the chance to extend then compress again.
Mind you I didn't do extensive testing cause I don't have a plow and just had sand bags thrown of the front of the machine with the hood off...lol. Again it wasn't awfull but the 200lb just felt better without making the ride much stiffer unloaded. I did keep my tire pressure at 5lb which could have contributed to it as well.
Shadesmn
Shadesmn
505
959
Ramsey, MN
Yes i got them for 249 plus shipping
Reactions: trigger
Shadesmn
Shadesmn
505
959
Ramsey, MN
So you think i should call them and switch to the 200lb? Im fine with doing that, espescially if i end up with not red coils as a bonus. Just dont want the 200 to be too stiff for the rest if the recreational use. If you think they'll be good without the plow load im fully ok with calling to have them do the 200s
196,510
I have a plow too but won't be doing much riding with it on. I figure I'll crank them up for plow season and then back down for trail riding. Just once I'd like to feel the front too soft on the trail. ;)
Shadesmn
Shadesmn
505
959
Ramsey, MN
I was thinking that as well. But if the 200s balance out better i figured id give them a shot over the 175s...not sure how much stiffer theyd be with the plow off and then adjusted softer vs 175s at a normal setting
Reactions: trigger
196,510
Don't forget that the dude told me they were doing some valving changes. Sounds like they may have been doing some R&D and got them figured out.
Reactions: Shadesmn
chrisC
chrisC
138
259
Newfoundland, Canada
If the plow drops the front a bit more then you like you could adjust up the preload a bit.Thats what sets the ride height anyways?
I'm guessing you'll only have the plow on in the driveway and not rough areas?
I'd guess all springs softer than the 250lb ones are eibach red? Anyone know?
Sent from my SM-G955W using Tapatalk
jay_man81
jay_man81
356
1,158
Central Pa
www.facebook.com
That’s true. I forgot they changed the valving so it’s hard to say how that changed the way the shocks are.
Reactions: trigger
