pct
Lost in the hills
Been down for a while and finally got to take the ole girl out and try the new tire setup all was great it handled the 31/10.50/15 tires fine but I came up on a big hole didnt have time to get stopped so I hit it water went every where and caused the motor to sputter lost rpms then came back alive and out of the hole got water in the filter pipe but not in the motor but the problem when I started it back up there was an E in the gear selector and when you put it in gear it would quit unhooked the battery the code left but would only move a little bit and took a real high rpm to move so we towed it home ( with a Honda pioneer 700 before you ask HaHa) got it home checked the oil and it was fine clean and no smell do you guys think it could be electrical I havent got to check it out much yet all ideas are welcome
Thanks,Paul
Thanks,Paul
