Mudder
Mudder
NTC/TAP Transition Member
11,727
88,913
On the suicide knobs, which model fits, is it same as some for lawn tractors at big box stores?
Mudder
Mudder
11,727
88,913
Could not resist showing this, matches my Vision Buckshot rims.
FE84178C 9FF8 4ADA BEC2 610FD1E71251 5AFDADCF 8C8F 45A5 B87D 97BABD4B2864
185,267
Riveted flexy flares on my rear fenders.got the idea from Solrus and his p500 buildView attachment 64772
Those look good! I didn't know that stuff existed. Way to give a shout out to @solrus too, I always try to give credit when someone gives me an idea. You just gave me this one. ;)
Reactions: solrus
rocmar
rocmar
4,741
5,776
4 CORNERS
Waitin...on some vids..
from your new camera...
Reactions: trigger
208,731
Now that is a good looking mud shield! I've been holding off on a mud shield, never seen a shield that I liked, until now. Would you mind telling us where you got them?
luckymike
luckymike
144
322
michigan
Low Range Off Road.they sell it by the foot.believe a few other places sell it.only thing I did different than Solrus was use 3/16 rivets because Menard's didn't have em.just make sure you also use a washer to back up the backside of the rivet
15183849517241341936450 15183850436131574963073
185,267
Thought about making one today of plowing snow but it would've been pretty boring.
I did change out the spark plug today and it looked like it needed it. Also changed out the air filter and it definitely needed it too. Then I mounted these WE...
Shocks Installed
luckymike
luckymike
144
322
michigan
Did you cut those corners at any certain radius or just what looked good?
Used an old drafting compass to scribe a radius and cut with a blade.i started in the middle of the fender and worked my way out leaving stock to trim ends off
Reactions: trigger
rocmar
rocmar
4,741
5,776
4 CORNERS
Looks........
BadAss......
Reactions: trigger
luckymike
luckymike
144
322
michigan
Shocks look great.i'm expecting a set any day and was wondering what you used to adjust the spring tension.is there a specific spanner wrench or just say a wood dowel and hammer to tap the adjuster around
Reactions: trigger
T
Texas_Newfie
53
115
Katy Texas
No heat...shield on that....
sittin on top of your radiator. ..
It doesn't touch the radiator and is not directly above it. Plenty of other plastic / wires closer to it that would be affected before the speaker tube.
SSL Under Hood 2
Reactions: rocmar
