Caper
Caper
7,789
11,004
Halifax Nova Scotia
DAA14FCD 4FE3 4509 86A8 C1C5CE431A6E
Finally!!!!!
Caper
Caper
Caper
7,789
11,004
Halifax Nova Scotia
83A175A1 1CD8 414D B9AC CFD3AB891191
Huh? What's that??? On a P500?????
I see your post on my email but not when I open the site.
Oh well.
I bought it from SXS Sports.Com. They are in California.
Sode by Side Sports . Com
They gave a 5% discount because of the site. Every bit counts. $40 US.
Total was $ 939.96. Plus exchange and taxes. That’s shipping included.
$180 to here , so probably half that to BC.
Hope it helps Al.
Can’t get it up here nowhere. Of course. :)
Our dollar sucks. :)
Caper
AlR
AlR
470
1,166
Nanaimo, British Columbia
Oh well.
Hope it helps Al.
Caper
Looks good. The writeup says it uses the stock bolting locations. Did you have to drill any new holes in the frame to install the skidplate?
Reactions: rtn001 and Caper
Caper
Caper
7,789
11,004
Halifax Nova Scotia
10 or 12 I think. Just along both sides and the very front.
Front is just a hole and bolt and nut, they come with it. And drill and tap 6mm holes in the pipe. Not a big deal. Keep the tap straight. Use some locktite, removable, and that will protect them and keep them in.
I used Neverseize on the rest. I used clamps to hold it in place.
A arms are easy, just a pain. :)
You know what happens when you don’t up here.
Anything else, just ask.
Caper
11,361
84,628
Finally cleaned up some under hood wiring by moving accessories from a terminal block to the sub harness power leads. Those sub harness wires are really small gauge, so only moved a horn, light and radio leads. Are they really rated for 15 amps?? Guess I’m used to using larger gauge wires. Anyone using one of the harness key-on leads to run a separate relay for higher amp circuit?
Caper
Caper
7,789
11,004
Halifax Nova Scotia
I have my winch switch, and my bar light hooked up to it. I think there is still a place for a horn and back up light. I have the diagram somewhere. :)
No problems yet. Haha
Knock wood. :)
The extra two are just taped to the top bar. For now.
I should have rad a wire to the back while I had the skid plate off. Da.
Caper
