The Green Goat
The Green Goat
1,747
12,374
Last week i pulled a General 1000 out of the mud at royal blue 💪 I forgot to turn my camera on until the very end but he was in deep. My Grand-Baby was in it so I had to get it out of there :)
I think I remember that hole!
I'm pretty sure I got stuck (high centered) in the hole next to it. lol
Snek
Snek
“Member” huh huh
649
8,370
Saint Augustine FL
Good for you man, I'm the feller you met at the comfort inn at royal blue when you were waiting on your old man to get off the trails. 👍👍
Ha ha when they finally showed up he said “no more prison rides for him”. And so we didn’t go to the prison the next day😂
You gonna make it to the meetup in October?
wvupsc
wvupsc
180
802
West Virginia
Did a little trail maintenance on the property around the house, put out some mineral blocks for my wife's pet deer and did some other chores. My P520 got a speck of dirt on it, so I gave it a bath before putting it back in the garage.
470DAE29 F13B 420F 9CB9 F16809AC49B1
5C2C2A0F AD3E 446B 970C 1C74B192342F
D690795D 239D 4FE6 B2CB 9F3BB8AE782B
hallic
hallic
320
1,795
Central MN
Installed @RB3offroad 360 degree antenna mount. I duno if they made it this way on purpose, or if it was a happy accident, but its like 95% perfect for what I wanted to do.
With the Honda OEM roof installed, pic from the underside of the rear ROPS bar, up is towards the rear:
PXL 20210717 215742648 exported 0 1626560511636
Measure once, drink a beer, then half-ass it with the dremel:
PXL 20210717 215751288 exported 0 1626560525720
Mounted Signal Stalk antenna and cabling:
PXL 20210717 221323988 exported 0 1626560538769
It's angled a bit to the front (a bit more then normal because it's hitting the garage door), I'd rather the mount had an angled piece so that it would be straight, or bent a bit to the rear, but the Signal Stalk is super bendy, so not worried about branches etc. To get the internals flat against the backside of the roof, it ends up angled like this. Hence the -5% from being perfect. All in all, more than worth the cost for the antenna mount, turned out much better then the half-assed plans I had originally been trying to do.
PXL 20210717 222423200 exported 292 1626560674737
jmaxch
jmaxch
12
81
Quebec
Installed Elka Stage 3 front and rear and removed the rear sway bar today ( can’t believe I didn’t do this already)… it’s night and day difference! I didn’t have much time to really test but I makes a HUGE difference.
The front shocks were very easy to change, I had little more difficulty with the rear one, specially the left side but once I figured out how to pry it back it was fine. The rear Elka 3 comes with some bushings and they fit perfect. No bushings in the front.
31C1E312 4006 456A A7B5 16B2BB874656
510C2327 B3D4 4CF3 945E 9D66FDA96D63
2B3803A0 A352 415D B88D 1479F7CAF596
crewcabrob
crewcabrob
1,029
4,038
Omaha
View attachment 284031View attachment 284032View attachment 284033
I’m super jealous of this upgrade.
Rob
70Bones
70Bones
888
3,779
New Brunswick Canada
Replaced the front output shaft seal, took an hour and a half and about 5 lbs of sweat, it was hot and humid.
Simply unbolted 3 bolts holding the front differential on, pulled it forward, then reached in the opening under the drivers seat and pulled the prop shaft off the output shaft by hand. Took a small slotted screwdriver and pried out the old seal, cleaned up the shaft, greased the new seal and slid it on and tapped it into place with a small block of wood and a hammer. Put prop shaft and front diff back on and Bob's your uncle!
Tom_C
Tom_C
141
446
Virginia, USA
Yeah, gave my new ride a power wash and once over inspection. Didn't do any aggressive wipe down, just power washed it inside and out. It will never look new again, cause I'm not into that, but it appears to have been mud bogged and need some flushing.
Wash1
Wash2
Wash3
Wash4
