BigOL3
P1K been running rough. Not really like spitting or cutting out usually, just not what is normal. It would act like it wanted to die when slowing to idle .... but not die. While looking for potential problem I noticed oily dirty film on this wire connection. What is this component the wires are plugged into????
When I unplugged it, I found oil all inside the connection also. I sprayed contact cleaner over it all and reconnected. It seemed to run fine. After about 10 min it started running worse. After removing the wire harness, I found it to be full of oil again.
Any guidance or info on what the component is/does is appreciated.
Sent from my SM-S901U using Tapatalk
