The satv arms should work fine for you. I had 30x10x15 warhthogs on mine no problems and I have a set of satv arms for sell front and back with honda balljoints and they are like new
If you go with SATV do yourself a favor and swap out the bushings from the get go.Thats one thing i was worried about thank jtw maybe i should do satv and stick with 28 evos nice ride btw
If you are planning on running a 30 or better.. yes. It seems the SATV’s will nickel and dime you.. ball joints, bushings, HL lift. But if you’re not going to run anything larger than a 28... we’ll maybe not. Also, Look at 12” wheels and 28” braven berserkers.Ok is cfab alot better
