So I dusted off the box for a Champion 3000lb winch I bought with a trailer about two years ago over the weekend. I decided its never gonna pull me out of anywhere in the box, so I'm gonna slap it on the Pioneer 1k. Before we start: I know if I was buying a new one I should go heavier, and I know that I NEED a dual batter set up, etc etc. That is all well documented here and I do thank everyone for those tips.
What I am trying to do is set this thing up as cheaply as possibly. I don't typically get myself into situations I don't KNOW I can get through, so this is happening more out of sheer boredom and desire to get the thing out of my basement than it is out of any real anticipated need.
I have a Viper plate ordered from @Hondasxs (thanks for your help earlier), and I will likely order a switch to mount to the dash as well. Here's a link to the controller that the winch came with:
3000-lb. Winch Kit - Champion Power Equipment
I pulled apart the switch because its way too big and ugly to mount anywhere in the cab, and I don't want to tie it up under the hood. What I found inside was basically what looked like a solenoid, and it appears the two large buttons on the front hook each "side" together with the grounds in the middle to create power.
Based on this configuration, it seems like i should be able to re-use the "guts" of this box as a solenoid and wire a cheap rocker switch directly into it. Does that seem to hold weight?
Does the solenoid serve any other purpose than to connect the correct groupings of wires at the correct time? I have looked at some YouTube videos that suggest that there are coils or current regulators in them, but I have also read that's BS and some folks run a winch straight to a switch without a solenoid.
What say you?
PS: I'll try to snag a picture this evening of the opened "solenoid/switch".
What say you?
