Windrock1000 submitted a new Garage Item:
Windrock 1000's- She's Foxy Now
Read more about this showcase item here...
Why’s your brain hurting?This makes my brain hurts
Just use @Windrock1000 ‘s measurements and everything works out great.
Even without the HL lift it works out.
Mine worked out to 8 turns out back and 10 turns out front-rear A arm. Since you have to make one full revolution to keep grease cert on top. I have a slight negative camber.
That is the 3rd set of measurements I've seen! I used the .88 and 1.03
Use windrocks . I did and it worked out fine. You dont have to be super accurate to those measures just real close.That is the 3rd set of measurements I've seen! I used the .88 and 1.03
All 3 were his measurements!Use windrocks . I did and it worked out fine. You dont have to be super accurate to those measures just real close.
These last post is the best setup! I’ve ran 4 different setups.That is the 3rd set of measurements I've seen! I used the .88 and 1.03
Because I haven't even taken delivery. So much to take in! LOL.
I pick her up tomorrow. It's a 2016 that I had them do the clutch update which took 10 days.
These numbers. .880 and 1.03. Will give you more camber.
Strongest wheel on the market! Bad! Great tire choice too! Private Roctane Party ride at the Takeover! I think we get in the door prize drawings twice too!
