P1000 Wiring diagram
T
Tbizzle
6
5
Fort Worth
I followed this diagram from the site ..
I'm at the DPDT Switch ..Not sure what switch I need 7 pin ..10 pin ??? and which numbered pin do the wires connect to? Diagram linked
  • Always on - Honda P1K Rob Wiring Diagram on-off-on with relay and dimmer v301.pdf
67,230
This switch has a nice wire diagram in the images.
115,818
Welcome from Michigan!
Got some Pics and info about your rig? Kinda a big deal here when you join. Pics Or It Didnt Happen! as we like to say. Also Pics and a explanation of what your trying to do will help us to answer your question. Otherwise its like Throwing darts at a blank board.
Hillbillytnt
Hillbillytnt
552
2,030
Ky
The club store sells a good master switch and the diagram shown is how I wired mine. Before that I used a 7 pin wired like this
602E5716 9226 4E42 A4FA 7F96EB26EE4A
Reactions: Tbizzle
T
Tbizzle
6
5
Fort Worth
Thanks! Brand new (middle of 2022) 2021 1000-5 LE. I'm doing the dual battery install ... using the dual battery wiring diagram (with key-on and bypass) from the site. I'm using the accessory bus .. I'm confused about the DPDT Switch .. 7 pin 10 pin? What number on the switch do the wires go to?I've seen a bunch of diagrams but none with this bus. And the the bus is dark red?
More pics to come.
TempImageJrYzHV TempImage5QCn7B
67,230
I'm still a little confused as to what you are asking.
Can you clarify "key on bypass". What do you mean?
----- The key-on harness from the club store?
As for what the DPDT switch will look like depends on which one you buy and its layout.
See the link to the HondaSxS 10p one I posted above and look at the wiring diagram.
Regarding the added bus.
It looks to be constant, so you could collect constant power there if you wanted to.
Also, Is that a negative bus I see?
Does it ground to the second battery and ONLY to the second battery?
You need to ensure proper power loops back to the second battery.
Grounding to the primary or to the frame could alter this path.
T
Tbizzle
6
5
Fort Worth
I'm doing the rocker switch with the two options ..key-on in one position and bypass in the other poison with no key needed.
right now I have a 7 pin switch .. I saw the 10 pin and the diagram that goes with it..
Good catch on the negative bus... I ordered the wrong color and have a red one coming.
The diagram shows the key on coming into the switch (top left) and the dual battery coming into switch (bottom Left) ... and then coming out the other side
Good catch on the negative bus .. I was sent the wrong color.. red on on the way.
I saw the 10 pin with diagram ..right now I only have a 7 pin.
The rocker switch two options are what I'm trying to do ..key-on in one position and key off in the other to run my accessories.
I've never done a seven pin before and wanted to make sure the wires were going to the right pins on switch.
Thanks for all the help.
67,230
Ok.
Here is your 7 pin layout.
- pin 4 is key-on.
- pin 5 is to the stinger.
- pin 6 will be constant (2a fused battery power)
Question?
How do you want the switch LED's to work?
I perfere ON when turned on. Off when off.
To do this. Jump pin #5 to pin #2.
Also ground pin #7
If your switch works reverse. Key-on= key-off. Then just flip pin # 4 and 6.
Hope that helps.
T
Tbizzle
6
5
Fort Worth
Ok.
- pin 4 is key-on.
Question?
Also ground pin #7
Hope that helps.
Awesome!...Thanks
T
Tbizzle
6
5
Fort Worth
Any update?
You get this done?
Almost ..The switch is working but I'm still looking into one small issue ...I'll explain later. I'm also working on getting dual volt meters to work with the relay that came with the True isolator. Just not enough time.
Thanks .. I'll post soon
Reactions: Lady01
T
Tbizzle
6
5
Fort Worth
2nd pic is the wiring I went with ...center pin hot (left) with out on the bottom pin... right side center pin hot with out on the top pin as in pic.
Auxbeam 8 gang switch panel
Crossroads dash panel for Limited Edition
Big thanks to everyone that helped.
TempImageCvRGgg TempImagej6vGgL TempImageAd2GEv TempImageXV8izZ
Reactions: Lady01
